Is this enough clearance?
Old Aug 15, 2006 | 09:57 PM
Spirit Rx-7's Avatar
rotard
im wondering if this is enough clearance between my coilovers and tires, they dont seem to rub, but their close enough for me to look into. Should I get 5mm spacer?
Old Aug 15, 2006 | 10:38 PM
LeeTheSlacker's Avatar
if its not rubbing now, it shouldnt ever rub unless you bend something or change tire size.
Old Aug 16, 2006 | 01:29 AM
ARD T2's Avatar
I can't tell from the picture but you have to account for sidewall and wheel deflection. So you should have about 3mm of clearance with some pretty decent tire pressures. Slightly above average.
Rishie
Old Aug 16, 2006 | 02:25 AM
RETed's Avatar
Yeah, it's hard to tell what exactly is in the pic...
...but, if that's the top part of the tire / wheel, the tire deflection is minimal.
If it's not touching now, I doubt it'll touch while you're driving.
-Ted
Old Aug 16, 2006 | 02:38 AM
rotard
i'll take a better pic tomorrow. its mostly the top part of the tire. im just worried about driving it hard, i do plan to track it again. and wondering if i should get 5mm spacers just to be on the safe side.
Old Aug 16, 2006 | 04:53 AM
you could just for peace of mind, just because 5mm spacers are way cheap.
Old Aug 20, 2006 | 04:20 AM
rotard
here are better pics:
by cheap 5mm spacer, you mean the ones at pepboys? how safe are those?
Old Aug 20, 2006 | 12:29 PM
F1blueRx7's Avatar
Couldn't stay away
As long as you run longer studs for the lug nuts, you'll be OK.
Old Aug 20, 2006 | 01:37 PM
ARD T2's Avatar
I think you'll be fine.
Old Aug 20, 2006 | 05:33 PM
rotard
yea, i already have arp extending studs. and it'll be nice if my front wheels stick out a lil more. how safe are they, since their not hubcentric.
Old Aug 22, 2006 | 07:45 AM
RETed's Avatar
That's freakin' a LOT of space!
-Ted
Old Aug 22, 2006 | 12:38 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
dude.. no problems there. I think I run a little closer then that and I have no problems. I cant even fit my little finger in between the shock on the tire.
Old Aug 22, 2006 | 12:42 PM
OC_'s Avatar
OC_
yay for dual posts!
Turblown
Sep 30, 2015 05:58 PM
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
