setting my tps
Old Aug 15, 2006 | 03:39 PM
88_10TH_AE's Avatar
setting my tps
im hopping that someone can lead me in the direction of how to set my tps. im a little new to repairing my rx, so if someone can tell me how to set it or maybe tell me where to go to find that info that would be great. thanks
Old Aug 15, 2006 | 06:17 PM
J-Rat's Avatar
Alcohol Fueled!
From the FAQ:
http://www.teamfc3s.org/info/articles/idle.html
Old Oct 17, 2006 | 06:00 AM
Force Fed's Avatar
Rotary Apprentice
That link doesn't tell you how to set the tps, it just tells you to set it.
Old Oct 17, 2006 | 10:45 AM
HAILERS's Avatar
HAILERS
Now I'm going to keep a copy of those words and spend the rest of the day trying to figure out the meaning. It Doesn't then it does????? Must be some deep meaning there. humor
And, is this a Turbo or non turbo car?
EDIT: Actually I'm not really interested in telling someone how to set the tps. On the whole it's a really pretty straight forward propositon. The FSM says a properly set tps at idle will output apporx 1 vdc. That's with a fully hot engine. So set it to 1 vdc and go on to doing something else. The green/red wire is the ouput wire on the tps connector and it's the same green/red wire where it enters the ECU on pin 2G.
If your into wasting your life away messing with the setting of the tps go read the FUEL section of the FSM and ohm the life out of that bugger. The end result, IF you do it right, is an output of..............one (1) vdc of the green/red wire on the tps plug.
Or you can manufacture the two LED lights for installation into the TPS CHECK CONNECTOR (green, three sockets) and follow the instructions in the FSM. It's a free and online FSM. IT"s in the FUEL seciton.
Old Oct 17, 2006 | 12:50 PM
stevej88na's Avatar
Strength and Honor
TPS resistance check and LED adjustment:
http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1
I may update that with the easy 1V method (or was it 0.95V?) method HAILERS mentioned. Or he could do it, I'm just not 100% positive how to do it with S4 and S5.
Old Oct 24, 2006 | 06:55 AM
RETed's Avatar
http://fc3spro.com/TECH/HOWTO/TPS/tps.html
-Ted
Old Oct 24, 2006 | 03:50 PM
NZ_87_TURBO's Avatar
long live the monster BP
how acurate to 1K ohm do you have to get? mine was set at 1.8 ( maybe it was cold i cant remember ) I will warm up and check tonight tho.
coz after i set it to 1Kohm it idoled really low- 600 or so
Old Oct 24, 2006 | 04:10 PM
My5ABaby's Avatar
Rotaries confuse me
It should be dead on at 1k ohm.
Old Oct 24, 2006 | 10:25 PM
RETed's Avatar
If you want to err, err on the low side.
Setting it down to 0.950k ohms is fine.
I tend to adjust it to slightly under 1k-ohm.
-Ted
Old Oct 25, 2006 | 02:35 PM
well, after many small ajustments i set it to 1.000k-ohms. its idoling about 700 but is a little wobbly ( just a little ) I will adjust my BAC to bring it up again
Microtech
30
Apr 23, 2016 06:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
