Power FC Power FC Connections
Old Aug 15, 2006 | 03:29 PM
LS1FC's Avatar
LSX7
Hey Guys
Installing my AP Engineering PFC in my car and Im wondering if the 3 pin connection on the side of the box is for the boost control kit? It sits right next to the PS2 connection for the commander. Any info is greatly appreciated.
Thanks
Chris
Old Aug 15, 2006 | 06:25 PM
GoRacer's Avatar
Speed Mach Go Go Go
^ yes, it is. There are no english instructions. You will use your 2-bar map sensor I beleive with that connection and it will be used as a barametric reader. The 3-bar will go where the OEM 2-bar was. The dual solenoids for the twins will be replaced with the single. You can try calling Apexi, here in Orange CA and ask for tech support. There is one guy that knows how to hook it up. They all have a slight accent but are helpfull.
Old Aug 16, 2006 | 08:08 AM
LS1FC's Avatar
LSX7
Actually I have an FC, so no twins here...lol
So its not like I can just take my new apexi solenoid and plug it into the connection that my old stock solenoid uses?
Old Aug 17, 2006 | 12:06 AM
GoRacer's Avatar
Speed Mach Go Go Go
I thought they were mounted together tlike the pic below
But mine looks alot different. I'm can't see both map sensors in the pic below.
Well, you don't just replace it. You still use the old one. I think mine is mounted by the PFC but I could be wrong. I thought the 2-bar plugs into the tiny harness and then in the PFC. Try calling Apexi and ask for tech support.
josef 91 vert
Aug 29, 2015 12:22 AM
andyvideopro
Aug 11, 2015 09:16 PM
