Sponsored by: CARiD
Boiling coolent- is it bad help guys
Old Aug 15, 2006 | 12:08 AM
rx7-kid's Avatar
Incomplete Project
Here's the problem guys, i was traveling on the high way for about 30 minute coming back home, while i was traveling on the highway the temp was in the middle of the half way point. but when i got home it was a little bit above the halfway mark, so i open the hood and hear coolent boiling. Is it bad for a rx7 to boil like that. i was thinkping that something is wrong with my car but cant seem to figure out what it was. My car is weird because if i was driving on the highway then it would cool down but as soon as i get of the highway it seems to heat up pass half way so i would have went home as fast as i could so i can let the car cool down at home. but like i said the coolent on the car would boil if it went pass the halfway mark. i was wondering if you guys could help me figure out the problem. thanks
Old Aug 15, 2006 | 07:57 AM
Kentetsu's Avatar
Make sure your belts are tight. Is the fan working?
Old Aug 15, 2006 | 08:01 AM
fd93texas's Avatar
The Purple People Eater
Thats the worst any 7 owner will tell you. I think its time for a rebuild. One of your seals gave way.
Old Aug 15, 2006 | 08:44 PM
rx7-kid's Avatar
Incomplete Project
my fan is working and the belt is tight i just hear water boiling inside the engine. but i dont know if my my water pump is down or not.
Old Aug 15, 2006 | 09:15 PM
melicha8's Avatar
Mazdaspeeding
Mine did that and it was because the coolant wasn't topped off
Old Aug 15, 2006 | 09:57 PM
trochoid's Avatar
Old Fart Young at Heart
Boiling coolant is always bad. Check the fan clutch, waterpump, thermostat and radiator. Check the belts too. Total deflection at the center of the belt betweeen the pulleys should be no more than 1/2". If you have a radiator cap on the radiator, look inside and see how the core looks, If it is getting crudded up, do a flush and fill.
Old Aug 16, 2006 | 10:57 PM
rx7-kid's Avatar
Incomplete Project
what do you mean wasnt top off
Old Aug 17, 2006 | 12:15 AM
SanityAssassin's Avatar
full?
Old Aug 17, 2006 | 02:21 AM
rx7-kid's Avatar
Incomplete Project
its full i make sure the coolent is full when the car cools down. im just worry about hearing the coolent boiling or something like that
Old Aug 17, 2006 | 10:18 AM
FC3S_DarkHorse's Avatar
I'm having the exact same problem with the coolant boiling. The thing in my case is that every once in a while, I will hear the coolant boiling and other times it's fine. Other than that, I usually add water everytime I stop. Is my water seal gone and if so, how long can I go without putting money into a rebuild?
Old Aug 17, 2006 | 01:28 PM
Aseras's Avatar
RX8 Lurker
try burping the car.. jack it up on one side and lower and jack it up on the other, and then top off the coolant and go for a ride..
Old Aug 18, 2006 | 12:31 AM
rx7-kid's Avatar
Incomplete Project
so do you mean that i have to take out my coolent and add new coolent in right? what the job of the water pump seal.
Old Aug 18, 2006 | 09:28 AM
r1xliquid's Avatar
your problem could be as simple as replacing the radiator cap. check your radiator cap and make sure there are to nicks or gouges in the rubber gromet. if there is the system will not hold pressure causing the boiling point to go down
Old Aug 20, 2006 | 10:25 AM
rx7-kid's Avatar
Incomplete Project
well i just change the radiator cap and i donnot hear boil no more however when im on the highway my car cools down but then when im on the street for about ten minute the car heats up and almost overheat on me. could it be that my fan is not working good. my car fan spins but i dont feel much are coming.
Old Aug 21, 2006 | 12:16 AM
r1xliquid's Avatar
good to hear the boiling seems to have gone away same thing happened on the FD i used to have
yeah i would look replacing the fan clutch (attached to the back side of the fan). not sure how to tell if its bad, but at idle it should be moving a substantial amount of air over the motor... as RPMs pick up the clutch should allow the fan to spin slower.
Old Aug 21, 2006 | 05:22 PM
rx7-kid's Avatar
Incomplete Project
the fan spins but i dont feel that amount of air that your talking about. my dad toyota pick up seems to spin faster creating more air than mine
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
