Sponsored by: CARiD
Engine will turn over but not fire. please help
Old Aug 14, 2006 | 08:14 PM
SanityAssassin's Avatar
OK! for the life of me...
lets start here, I purchased a 1986 Rx-7 GX
from an autowreckers for 600 dollars. I am
not naieve into buying a car that is hopeless
and this is why i purchased it. It turned over,
everything and i mean everything electrical
worked in it including power side view mirrors.
All engine components were present so I
thought it would be alot! easier! than it is!.
The spark plugs were done, so I replaced them,
still not igniting. replaced the old gasoline in
the engine, replaced the fuel pump because
afterwards i checked to see if it was working,
it was not. so i paid 250 goddamn dollars for
that and it turns out the wiring to the pump
has no power. **** off, so i booster the fuel
pump with another battery. worked fine and
it actually can get the car started long enough
for it to rev up to 2000-2500 rpm and it quits.
I've come to the conclusion there may be a
break in the wire. Or possibly the Computer is
toast? very effin hoping thats not the case.
Im one step away from taking it into the dealership
but i thought i should ask here first...
any other suggestions people?
Old Aug 15, 2006 | 07:59 AM
Kentetsu's Avatar
You might get more help if you post in the 2nd gen section of this forum...
Old Aug 15, 2006 | 01:14 PM
EricRyan's Avatar
Autocrossed. I got CONED!
Mazda dealerships tend to not service +15 year old vehicles.
Old Aug 15, 2006 | 02:34 PM
Chuck's Avatar
Sounds to me like you have a massive vacuum leak somewhere. Check the vacuum lines and the gaskets at UIM and LIM. Crank and stall usually means a lot of unmetered air is getting into the system.
Old Aug 15, 2006 | 07:44 PM
i did post this in the second gen forum as well...lol
no way why would they do that...****!
and thank you.! some useful information
for me to try. any other possibilites?
Old Aug 15, 2006 | 10:10 PM
trochoid's Avatar
Old Fart Young at Heart
In the 1st gen archives there is a link to the online FSMs. Rotary refs is mentioned in the thread tittle. Download that and and go through the trouble shooting section on starting.
Old Aug 17, 2006 | 12:08 AM
il try that thanks...
Old Aug 19, 2006 | 01:53 AM
thekingsherman3's Avatar
if you have no power to the wires its simple get power to the wires..trace them to were ever they go and if you cant find the break/bad point while tracing them i would just replace the wires
Old Aug 19, 2006 | 03:32 AM
replacing the wires alone doesnt guarentee anything though...ive thought of it but if its something more serious like the ecu or something then ill have to replace that
Old Feb 12, 2009 | 08:29 PM
darkprince134's Avatar
is the engine flooded? pull the 40AMP fuse labled for fuel injection,crank the car for like 10-15 seconds(occasionally it may actually run) then turn the car off,put the fuse back in,and turn on your car,very common problem...
verry common fix
the fuse will be in the engine bay on the right side
cristoDathird
28
May 30, 2019 08:47 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
