Sponsored by: CARiD
trouble with 93 rx7
Old Aug 12, 2006 | 11:25 PM
thekingsherman3's Avatar
trouble with 93 rx7
when im drivin i cant rev past 6,000 rpms..but when im out of gear i can rev as high as i want...the suggestions ive read about that realate to my problem are to check the vac. and see if it holds good preasure and adjust the tps if it isnt bad and to clean the grounds from the 2.nd injectors. is there anything else to check and fix?
Old Aug 13, 2006 | 03:28 AM
Omixeo's Avatar
'89 GTUs
Check which year your car really is, .
Old Aug 13, 2006 | 09:54 AM
it is a 93...they made rx7 till 95
Old Aug 13, 2006 | 11:58 AM
It could be one of a million things. If you havent done so already, install new spark plugs, wires, fuel filter. For problems like this you would be well served to go to the nearest rotary specialty shop. Cali has many of them, but be prepared to pay a premium......
Old Aug 18, 2006 | 11:23 PM
SanityAssassin's Avatar
they made rx-7s to 2002*
only 1500 of em but they did
Old Aug 19, 2006 | 01:41 AM
yeh well alldata only shows them up 95 i think...or 97 im not sure but whatever you say as long as i can get my car to rev past 6000 so i can start racin again
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
Junkee
Aug 15, 2015 01:57 PM
Marty RE
Aug 13, 2015 11:19 AM
