help asap please
Old Feb 24, 2002 | 09:10 AM
Zalitore's Avatar
help asap please
hey , does anyone know where the seat belts bolt up i can find where it attaches, my friend took it off and i dont talk to him anymore cuz hes dumb, but anyway any scans of the haynes manuel would be extreamly appriciated thanks, im slowly putting my car interior back togeather and its confusing but im not doing to bad, if u have anything that i should know on putting it back togeather special screws or something to look out for please let me know i didnt take it apart so its hard to peice it back togeather and without a haynes manuel(its been on order for over a month) i just have to put it togeather like a puzzle
Old Feb 24, 2002 | 12:14 PM
Zalitore's Avatar
hm... someonse gotta know how to mount the seat belts
Old Feb 24, 2002 | 12:24 PM
Barwick's Avatar
SCCA Rookie
dude, if you're going to work on your car, buy yourself a manual, you can't do much without it.
yayarx7's Avatar
Are you Nucking Futs?
which mounts. upper lower the retractor?????
helps us out
Old Feb 24, 2002 | 06:28 PM
cjf's Avatar
cjf
Be a little more specific about the seat belt problem. I don't get it?? 1st, what year car you have? I have 84-85 but if you have a different year, it may??? be different...are you talking about the retractable part or the part that clicks in?? If you give more info., you might get an answer that might help you a bit...cjf......
Old Feb 24, 2002 | 09:01 PM
Zalitore's Avatar
ok the seat belt itself theres 3 moutning places, i tried to buy a manuel its been on order for a month, i have a n 85 GS , i have the part that it clicks into on it bolts by the center counsul thats easy but i cant figure out where the actually seat belt bolts up theres 3 places i know where the middle part bolts up to by the roof but have no clue on the other 2
Old Feb 25, 2002 | 03:02 AM
RotorMotorDriver's Avatar
Seven Is Coming
On my cars, (85 GSL, 85 -SE), there are three places where the seat belts mount to the car. Also, I stripped some seatbelts off of an 81 GS and I know theyre the same. Anyway, there is the female end that bolts to the center console (one bolt), the actual retractor unit that bolts to the inside wall of the car UNDER the storage bin area (take out the storage bins and there will be a place to bolt it there (one bolt), then there is the top directional piece that bolts up by the headrest of the seat, also on the inside wall of the car (also, one bolt). Other than that I dont know how to help you. I hope that helps though.
~T.J.
PS - If you have the place on the center console bolted up, the other two use the same kind of bolt i believe. its a big one, about 17mm i think
Old Feb 25, 2002 | 09:37 AM
Zalitore's Avatar
sweet thanks man, i got it in
Old Feb 25, 2002 | 10:17 AM
hanman's Avatar
BTW, if you need a Haynes, buy one on Ebay, cheaper and faster than ordering from a book store.
hanman
Old Feb 25, 2002 | 06:46 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Zal, go to your local Candian Tire. They should be able to getg you a Hayes for your car withing a couplem of days.
