can I use the stock locking lugnut with my volks?
Old Feb 23, 2002 | 10:25 PM
weaklink's Avatar
Resident Retard
Does anyone know? Any other options?
Old Feb 23, 2002 | 11:49 PM
Pumped's Avatar
from what I recall stock lugs have a round edge to them and volks have a tapered edge... so ..no
Old Feb 24, 2002 | 12:09 AM
maxcooper's Avatar
WWFSMD
I think they are fine on the clamping end. I am using a bunch of stock lugs on my SE37Ks after I galled a bunch of the ones that came with the Volks at the track (Hint: don't torque them over 85 ft-lbs, especially if you'll be cooking your brakes).
The only problem is that the key for the wheel-lock lugs is about the same size as the hole, which means you'll probably scratch the sides of the hole. For that reason, I don't reccomend the stock locks. I am sure you can get some locking lugs that have a smaller diameter key, though.
-Max
Jutta_J
Mar 25, 2017 11:24 PM
diabolical1
30
Jan 30, 2016 05:50 AM
Snoopy FD
Dec 8, 2015 01:45 PM
