Sponsored by: CARiD
compression test, motor outside,starter run but the motor not..
Old Aug 6, 2006 | 12:13 PM
tidanb0utch's Avatar
hi, i have try many time to test my jspec motor.
i have a booster pack ,battery and booster cable, i put the - on the motor body,
and the + on 1 bolt on the starter.
the result: my starter run, but the flywheel dont.
i have try whit turbo starter, tranny and flywheel and no turbo tranny, starter and flywheel. each time same result, starter run but the motor doesnt.
What i dont do right?
if some one can help me whit that, i will be very very happy .
Old Aug 8, 2006 | 11:48 AM
trochoid's Avatar
Old Fart Young at Heart
You need the turbo starter and flywheel, you don't have to have the tranny mounted, but the starter will need to be shimmed without the tranny. Ground to a starter mounting bolt, + to the outboard lug on the starter and a hot wire to the starter solenoid.
Sounds like either the starter gear is not extentending to engage the flywheel, or the starter and flywheel are not lined up.
elfking
Aug 19, 2015 09:48 PM
