swap pressure sensor in a supercharged engine?
Old Feb 23, 2002 | 08:41 PM
larsyoung's Avatar
Someone posted a while ago that convertibles, 1988 particularly in this case , have a N338 ECU, which is compatible with the 86-88 Turbo2 engine and harness.
I also read in another post that the pressure sensor in RX-7s cars control timing retard rather than fuel delivery. This doesn’t seen to be definite, but likely.
Since I'll be supercharging my engine ( sc kit has been sitting in the garage for 3-1/2 months!), is it possible to swap out my n/a pressure sensor to a turbo2 boost sensor? I hoping to do two things:
1) gain benefits of timing retard under boost. Even though I’ll only have 6 psi, anything to help engine longevity would be nice.
2) Install a turbo2 gauge cluster. The stock boost gauge reads the signal off of the pressure sensor to ecu wire. I know it's pointless since the stock boost gauge is known to have it's problems, but I have a series 4 and a 5 lying around and it would be something interesting to try.
Lars
Old Feb 23, 2002 | 09:41 PM
cymfc3s's Avatar
I Raise Chickens
The NA is a 1 bar MAP, and the T2 is a 2 bar MAP. You cant just put the 2 bar MAP sensor in, it wont work. Youd have to use a turboII ecu.
Old Feb 24, 2002 | 08:31 AM
larsyoung's Avatar
From what I understand, the 1988 conv. basically has a turbo 2 ecu. Therefore, it could swap in.
Lars
Old Feb 24, 2002 | 12:54 PM
RETed's Avatar
You're correct, but you still need the Turbo II engine harness to get the N338 ECU to react correctly...
-Ted
Old Feb 24, 2002 | 02:00 PM
larsyoung's Avatar
I've looked at a few wiring diagrams and it looks like the pressure sensor wire is the same in each. The brown wire w. red strip going to the 2B position, whatever that is. The only difference is a tap for the boost gauge.
Are the wiring connectors somehow different?
Lars
befarrer
Microtech
Aug 22, 2015 05:52 PM
20B Forum
Aug 18, 2015 02:46 PM
eddierotary
Aug 16, 2015 04:12 PM
