what are good drifting tires
Old Aug 3, 2006 | 10:53 PM
RX7 Kid's Avatar
i just started drifting and right now im useing bridgestone potenza and i need to know if those are good or if i need to keep those and get new ones
pm please
Old Aug 3, 2006 | 10:54 PM
cdaleracer669's Avatar
yes,thats me \/
you should know if those are good or not by the way they are performing...... i also hope your keeping this drifting on a track so you dont F up the car or someone else!
Old Aug 3, 2006 | 11:05 PM
SayNoToPistons's Avatar
Insane Burning Diarrhea
rims.
Old Aug 3, 2006 | 11:08 PM
TougeRoads96's Avatar
Rotary Love
well I work at Discount Tire so I deal with tires all day...just keep this in mind when buying tires the speed rating and the tread design I see alot of drifters at my store if you are new to drifting then best way to decide is by process of elimination...check out something simple like some Khumo 712s
Old Aug 3, 2006 | 11:17 PM
toplessFC3Sman's Avatar
If you've just started drifting... on a track or other venue away from the public... you should start with cheap tires. You are going to be burning thru them more quickly than your skill/experience is increasing, and it will take a while before your choice in tire will greatly impact your ability to drift. What might help is to get a spare set of rims with cheap tires, and swap them onto the back whenever you go to this closed course to drift (keeping the more expensive, stickier fronts on the car). That way you'll save the better tires for the street (where they'll hopefully keep you on the road better), and the car will want to oversteer more when you are practicing drifting, giving you more opposite-lock time
Old Aug 3, 2006 | 11:29 PM
lupin's Avatar
Rupanrx
get cheap tires, do a few burnouts
ready for drifitng
Old Aug 3, 2006 | 11:35 PM
robtechfabrications's Avatar
needs an FD
for just practicing until you get good buy used tires with a descent amount of tread left cuz ur gonna brun through em...also get a second pair of wheels to put the drift tires on and swap them so you dont brun up nice DD tires.
Old Aug 4, 2006 | 12:01 AM
ColdSeven's Avatar
in between builds
i starteddrifting over a year ago...and started with **** tires and sticky on the front,it worked great then moved up to 17's...i have potenza's and they heat up too fast for my N/A car...when my swap is done next week might be better but too sticky for the stock set up.
good luck
Old Aug 4, 2006 | 12:05 AM
Sideways7's Avatar
Yeah, I could see hoe 712's would be good for drifting. I had those on my rears when I bought the car. They had decent grip, but not a ton by any means. They seemed quite pradictable and controlable. I did some unofficial drifting on abandoned parking lots in them and they seemed to do well. Plus theyre cheap.
SirCygnus's Avatar
whats going on?
just go to some shitty tire shops. usually run by black people that speak french. tell them you want shitty tires that are still good. or goto the junkyard and just start yankin ****. serriously. keitchi tsuchia (sp?) even suggested getting junkyard tires for drifting in the drift bible dvd, which is a damn good dvd to have btw.
Old Aug 4, 2006 | 12:10 AM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
REally its up to you to make the desicion on what tires you like and what you can afford.
Old Aug 4, 2006 | 12:43 AM
reatrdedspleen's Avatar
D1 Drifter Status
Whats the cheapest tire you can find? how many of them do they have? buy them all.
Buy the best tires you can afford for the front, the stickiest. Buy the cheapest tires you can find for the back. keep at least 2 extra rims with tires on them in back. go drift, when you pop a tire, swap it. Dont stop till they pop. people might freak out saying your shootin sparks.. ignore them. just pop the tires...people like that.
unless your Rich, have a really good tire sponser, or are just stupid, dont buy expsensive rear tires for drifting. Cause when you get semi decent at drifting, your gunna burn through 4 rear tires in just a couple hours. No need to waste money.
Old Aug 4, 2006 | 12:48 AM
fcboy89's Avatar
id go with falken 512 ziex tires. they last long, and not to mention they're all season tires. and insanely cheap. i got some for around 60 each with free shipping. 17 inch tires btw too. for the front that is. if anything cheap or used tires for the rears.
Old Aug 4, 2006 | 01:25 AM
Valkyrie's Avatar
Mediocre grip, though...
Old Aug 4, 2006 | 02:48 AM
I've got something a little different to say...
first of all, how much power do you have? is the car N/A or turbo?
the best idea IMHO, is to balance the tires front and rear. if you don't have much power, run a mediocre tire on all 4 corners (like a 205 series all season). if you have a decent amount of power... well, basically just run the stickiest tire you can spin/afford. running a really sticky tire in front, and a really bad tire in back, IMHO, is not good, and just makes it a lot easier to spin, and gets real frustrating, esp. in snappy cars like FC's (if thats what you're driving...). just balance out your tires as much as possible to give you a good feel for the car.
Old Aug 4, 2006 | 03:02 PM
maxcooper's Avatar
WWFSMD
Saying that you are running "bridgestone potenza" is not specific enough. That could mean any one of a number of different tires. It is like saying you are dating a mammal.
-Max
Old Aug 4, 2006 | 03:19 PM
bacek's Avatar
falken rt 115
Old Aug 4, 2006 | 08:52 PM
fcboy89's Avatar
come to think abt it, scratch the ziex's. my car wasnt gripping on a curve after 45. it started slipping i mean.
Old Aug 6, 2006 | 07:50 PM
LeeTheSlacker's Avatar
i run ziex 512's in 205's on the front and whatever i can get on the back. The ziex's have a ton more grip then the dunflops that came on the car.
Frisky Arab
13
Aug 18, 2015 05:30 PM
