Recommendation on tires???
Old Jul 31, 2006 | 04:36 PM
rspunk96's Avatar
Im using Mazdapunk87 now.
Right now im trying to decide which tires would be better. im looking at the BFGoodrich G-Force KDW or Toyo T-1s ... or what Tires have you guys found to be a good tire ?
Old Jul 31, 2006 | 07:36 PM
Upgrayedd's Avatar
Double Dose
Toyo's SUCK A$$!! Had em on my FD and could never get traction in ANY weather without mods. I am now running Dunlop DP5000's which run about the same price as top of the line Toyo's and they are 2 billion times better! Super sticky! Love em!
Old Jul 31, 2006 | 10:08 PM
Kill No Cone's Avatar
Azenis 615, sticky and cheap. Take a look in Grassroots Motorsports at thier reveiw.
Old Jul 31, 2006 | 11:16 PM
BicuspiD's Avatar
Infamous...Butcher...
Advan A048 FTW! Best dry tire I have ever run
Old Jul 31, 2006 | 11:41 PM
notveryhappyjack's Avatar
1 bar boost
BFGoodrich g-force KD is what I ahve and I have never seen a better tire on any car, stiffest sidewalls and amazing dry traction go so fast around corners its scary, be prepared to swap em or hang up the keys to the RX in the winter tho as they don't do good in the cold
Old Aug 1, 2006 | 12:03 AM
cartapex's Avatar
Advan 032R are awesome DRY ONLY tires. In a 17 you can get them for around 159 each on Tire rack. Haven't tried the TA..The T1-R I have on my Element and they do really well...Had the T1-S on the 7..ok for about 5 laps then pppppppppplllllllttttttt. They are awesome rain tires however. I still have my T1-S...700 miles on them on a set of Panasport (spell?) racing wheels......hmmmmm 225/40/16...Actually took the Element out to PIR because I had paid for the session day and go figure..the 7 was down at the time!! I don't think even slicks could have made a difference, but it was funny anyway!!
Old Aug 1, 2006 | 01:48 AM
F0RSAKEN's Avatar
Cheese
Huh, I like my Toyo T1-S, but I really havent pushed them much. My preference is Bridgestone Potenza S03's. Thats what I had on my Corrado, and gawd damn were they nice. Awsome dry, and very good wet traction. Very balanced.
Old Aug 1, 2006 | 08:33 AM
.Zero's Avatar
+1
have them on my well currently blown up motor. very sticky and decent in the rain. and if your running 15's like i was then the price ranges around 50-60 a pop.
yeah with the vert bbs wheels + turboII... still with those tires i had very little traction issues
Old Aug 1, 2006 | 11:53 AM
SPACE WRANGLER's Avatar
Originally Posted by .Zero
+1
+2 I don't run them but my buddy does on his 8 and the only bad thing he said was out on the track on a hot day they got really greasy towards the end of the day
I run Yokohama AVS ES 100's on my 3 which have really sweet WET and DRY traction and through America's tire they are pretty cheap. I haven't been able to run them really hard on the track yet but they seem to hold up so far. Way better than the stupi P.O.S. Goodyear RSA's that come stock
Old Aug 1, 2006 | 12:14 PM
cartapex's Avatar
Space...I have never seen you drive "sweet" so shut up....*** clown
Old Aug 1, 2006 | 01:52 PM
rspunk96's Avatar
wow, thanks guys , i didnt expect to get so many replies,im running 16's right now, but thank you for the replies!! means alot .
Old Aug 1, 2006 | 02:27 PM
bstrange99's Avatar
unregistered rex offender
Only one reply with actual numbers to back it up?
What formula did you use to come up with this number?
Old Aug 1, 2006 | 03:14 PM
I never drive "sweet" the tires do . I 'm just all over the place
Well at least at this moment I have a running car .....
Old Aug 1, 2006 | 03:52 PM
Upgrayedd's Avatar
Double Dose
Well I used the formula given in the latest issue of Import Tuner... If you multiply how many miles per hour the tire is rated for by the number of grooves in the tire and divide that by the road temperature and add 39 to that you get your answer... AFTER multiplying that by the weight of the concrete per square inch on the road... And add in weather for the variable... It's SIMPLE math!
Old Aug 1, 2006 | 04:01 PM
If it's asphalt do you divide that number ?
Old Aug 1, 2006 | 05:24 PM
Upgrayedd's Avatar
Double Dose
Asphalt you subtract 13 degrees from the road temperature and add 3,679,087 after all the other calculations. That would put you OVER 2 billion times better on asphalt! You can thank Thomas Edison and Albert Einstein for the formula and Import Tuner for publishing it... Otherwise I wouldn't have such accurate numbers to provide as evidence that Toyo tires REALLY suck....
Old Aug 1, 2006 | 06:04 PM
Mna I hear you on TOYO's .actually I hate Les Schwab more than I hate the tires.
Old Aug 1, 2006 | 06:26 PM
rspunk96's Avatar
ROFL
Old Aug 1, 2006 | 06:28 PM
rspunk96's Avatar
I think im gonna give the Azenis 615's a shot , thanks again for your help...and equations....dont forget tho...to add +50hp for putting the tire comp. sticker on back window
Old Aug 1, 2006 | 09:22 PM
Boost Lee's Avatar
Dark Lord of the Drift
You won't believe this, but the Fuzion ZRi have proven to be an excellent street tire and they hold up pretty good on the road coarse. The unbelieveable part is the tires are like $100 for a 255/40/17 at discount tire.
They are nearly silent in turns too.
Old Aug 3, 2006 | 12:24 AM
cartapex's Avatar
********EAT MY ***********
Old Aug 22, 2006 | 09:37 PM
rspunk96's Avatar
LOL!!!so this is what happens when i ask for help on good tires....lol , i love being an FC owner!!
Sudowoodo
19
Dec 28, 2020 06:30 AM
rx7jocke
72
Jun 17, 2016 03:48 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
