Pickup truck
Old Jul 29, 2006 | 12:58 AM
jdr821's Avatar
Pickup truck
Would the transmission of a mazda b2200 bolt on the rotary engine?? Im thinking on putting a rotary engine on my pickup truck. Please let me know, thanks
Old Jul 29, 2006 | 01:06 AM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
Yes and no.
Old Jul 29, 2006 | 02:01 AM
Pele's Avatar
Right near Malloy
Yes it will. Check for some swaps on www.mazdatruckin.com
Old Jul 29, 2006 | 03:17 AM
Play Well
I thought you had to modify the bellhousing some, nothing real major. Thats why I put yes and no. Time to find another Starion.
Old Jul 29, 2006 | 10:25 AM
no_name's Avatar
Duct-tape fixes all
That is insain. Now I might be buying a Mazada B 2200 and swaping in a 13B n/A from a second gen as a beater for next yera instead of a Volvo lol.
Old Jul 29, 2006 | 05:46 PM
NeedFD's Avatar
R. R. R.
yes
Old Jul 29, 2006 | 06:00 PM
no_name's Avatar
Duct-tape fixes all
What kind of mods have to be done to make it all work?
What do you think the total cost of doing a rotary swap in a b 2200 would be?
Old Jul 29, 2006 | 10:01 PM
rxtasy3's Avatar
i thought u had to swap the bellhousing with one from an rx4 or t2 tranny.
Old Jul 29, 2006 | 10:43 PM
Play Well
That ******* trans is a *****, its the same one thats in the starion and conquest.
Old Aug 1, 2006 | 12:28 PM
rotary crazy's Avatar
are the gear ratios good for a rotary? i mean the engine the b series have are tuned for low end
Old Aug 1, 2006 | 01:59 PM
Rotaryhaven's Avatar
Total Rotary Domination!
You have to get the one from a Mazda B2600. It has the removeable bell housing, put the T2 or RX-4 one in with slight modifications and you are good to go. Supposedly it's a good tranny and a lot of budget racers use them. Same splines as a T2 also.
Old Aug 1, 2006 | 03:18 PM
are gear and pinion sets available for these truck to change the final gear ratio?
Old Aug 1, 2006 | 03:59 PM
no_name's Avatar
Duct-tape fixes all
How much does this cost to do? Can I do it in my garage with limited tools lol ( I am creative). I need a beater truck and rotaries are good
Old Aug 1, 2006 | 10:29 PM
Mareksa's Avatar
Just use the T2 tranny as I did, you'll need a new driveshaft.....I've been working on mine in my own garage for 2+ years, I don't have a lot of free time. It can be done realitively cheap, but you will need a welder and some creativity it is not just drop it and go.
Old Aug 2, 2006 | 02:33 AM
KeloidJonesJr.'s Avatar
strictly business
TurboII's are like the universals of all shtis.
Old Aug 2, 2006 | 06:51 AM
I wonder what dif ratios you can find for this , since the oem one is like a 3.60 or something, this is a proyect I love to do someday
Old Aug 2, 2006 | 11:41 AM
Pele's Avatar
Right near Malloy
It's the Mazda model R (Type III) transmission. It's used in everything. Hell, even Ford uses it in the F150 and Ranger.
Old Aug 2, 2006 | 03:01 PM
Siraniko's Avatar
RX for fun
Ring and Pinion.
Any possibilities that a ford ranger 4x4 would have same front diffy as the mazda 4x4?
Old Aug 2, 2006 | 10:01 PM
Play Well
Arnt they the same truck
Old Aug 7, 2006 | 01:46 AM
captain carnage's Avatar
depends on what year, 93 and on is all ford, and i believe 84 and down ford courier is all mazda, and i imagine that there are plenty of different gear ratios used in the mazda trucks, i believe the early 80's version had interchangeable ring and pinion gears with the fb's... so then you could have what? a 3.9 i think?
