Glowing Downpipe
Old Jun 11, 2001 | 11:08 PM
Glowing Downpipe
I recently added a downpipe along with a used stock cat (didn't appear clogged). When I start the car up and idle for less than 5 minutes the downpipe is glowing orange. I read in earlier posts that either the cat is clogged or air pump is not working. I also hear a strange sound coming from the the airpump area on startup so I suspect the airpump. Would a bad airpump cause the DP to glow so quickly? Any advice would be great. Thanks.
Old Jun 12, 2001 | 12:09 AM
spyfish007's Avatar
Yellow Dragon is no more
Easy way to check. Disconnect the cat and turn car on . . . if problem goes away then it is your cat ... else back to drawing board . . . . I personally expect it to be your cat . . . but take the time and do the test.
Old Jun 12, 2001 | 09:09 AM
ejmack1's Avatar
Lawn Ornament
hey im gettin a wierd noise from my airpump also and it seems like my car is runnin a little hotter now that there is that noise????
Old Jun 12, 2001 | 02:53 PM
spyfish007's Avatar
What is your setup?
Old Jun 12, 2001 | 03:24 PM
My setup is a 93 touring which is stock except downpipe. I also have a new bosch O2 sensor.
Old Jun 12, 2001 | 07:02 PM
TYT 7's Avatar
It's normal for the downpipe to glow orange at startup, thats when ur air pump is injecting air into the exhaust. You didn't notice before because you probably had your heatshield from your stock DP. If you disconnet your air pump, it won't glow anymore (try it), but then your main cat wouldn't last much longer.
Old Jun 12, 2001 | 10:36 PM
spyfish007's Avatar
I guess one question for you is . . . does the entire DP glow or just the upper part? I guess when I first read this, I thought you meant that the entire thing was glowing!
Old Jun 13, 2001 | 06:34 AM
Just the upper part of the DP is glowing. I'm glad to hear that it's normal on startup. I assume it stops when the car's warmed up and not running as rich.
Thanks for the help.
Old Jun 13, 2001 | 06:59 AM
Rotary Master
The upper part will glow after spirted driving as well, you have the highest exhaust temps at that point. If I remember correctly the exhaust temps out of the engine can reach 1300 F.
Old Jun 14, 2001 | 04:20 PM
R1 POWR's Avatar
Question
anybody know anything about Jet-Hot coatings??? i was considering sending my HKS DP to them to get their Jet-Hot 2000 coating. i think it's good for up to 2000F. hopefully it should help keep engine bay temps down. they quoted me a price of $82 ($60 coated inside & out + $22 return shipping).
comments anyone?? good or bad?????
93 BB R1
-GReddy SP exhaust
-OEM K&N filter
-HKS downpipe (not yet installed)
-Pettit column-mount boost gauge
-Pettit SS brake lines
-Hawk HPS pads
Old Jun 14, 2001 | 06:48 PM
yeah...I would suggest the jet hot coating. Thats a pretty decent price. It usually goes for about 70 plus hipping. So u said 72 wit shipping..If u have tha patience to wait and sending it in, go for it. Ur gonna bug out when ur dp is in...spoooool!
94 MontegoBlue Touring:
Blitz MSTT
Petitt SS Downpipe
K&N Dropin Filtercharger
Hawk HPS brake Pads
AutoMeter Boost Gauge
Stock Vented BOV
Redline TransmissionFluid
Redline Rear Diff Fluid
17" ROH Adrenaline Wheels
Old Nov 23, 2001 | 02:03 AM
RedR1's Avatar
Out of order
R1 Powr, who are you sending it to? Could ya please post a link.
thanks in advance.
Old Nov 23, 2001 | 04:24 AM
Cetchup's Avatar
The Cursed FD
Jet-hot coatings
I believe this is the site he was referring to.
www.Jet-Hot.com
Old Nov 23, 2001 | 04:26 AM
Cetchup's Avatar
The Cursed FD
Click on "About Jet-Hot" to learn about the differnt applications and Locations.
Tempe, AZ
Pascagoula, MS
Bridgeport, PA
Old Nov 23, 2001 | 02:40 PM
Yeah, lately my airpump has been intermittently making these "chirpping" noises. Is this a sign of an airpump going bad? Or is normal for sounds to appear everynow and then?
