Shocks for 3rd Gen
Old Jul 27, 2006 | 09:43 AM
gotigers62's Avatar
Shocks for 3rd Gen
I have a '93 rx7 with 47,000 miles. I want to replace the shocks but want to know what most people put on there cars and why. I know I only have 2 or 3 choices other than oem.
Any in-put will be welcom.
Old Jul 27, 2006 | 11:30 AM
jramosrx7's Avatar
As usual, this depends on what your objective is. Need more info, use, budget, DIY or shop install.
If it's primarily for street use and/or minimum autox or track, I'd recommend Tokico Illuminas (with Eibach springs), relatively inexpensive with some adjustability. If you are also autoxing or tracking the car, get a coilover set.
Old Jul 27, 2006 | 11:31 AM
dgeesaman's Avatar
But check the rules for the class you intend to run. Coilovers for example are not allowed in SS class for autocross.
Dave
Old Jul 27, 2006 | 06:04 PM
gotigers62's Avatar
More shock info
You asked for more info. I don't plan on doing a lot of racing just a Sunday driver and to the track once in a while. I'm looking for the best handling suspension without spending an arm and leg. I know I'm looking at $400 to $500 just for ride control before looking at coil changes.
So, for this application what would you guys reccommend.
Old Jul 27, 2006 | 06:27 PM
jramosrx7's Avatar
Tokico Illuminas and Eibach Pro-kit springs. With 47K miles on the car, the OE springs are still probably OK, but might as well do the swap with the fresh shocks, IMO.
