I knew our locks sucked, but DAMN!
Old Jul 24, 2006 | 07:34 PM
Sideways7's Avatar
I've heard that many people can open the locks on other FC's with their own keys. Well, this takes the cake. I was moving my 7 today and had the key in the ignition to keep the steering from locking. When I took the key out, I realized that I had used the key to my MX-3 out of habit. Thats right, my MX-3 key worked in my ignition. It was a little stiff, but still. Wow.
Old Jul 24, 2006 | 07:51 PM
riverzendz's Avatar
Interruptor Illuminada
I've started my n/a with a phillips head screwdriver...
Old Jul 24, 2006 | 07:52 PM
FirstRotaryExp's Avatar
The Brap is Back
yeah....both my keys open and run my brothers fc too, ive got a 88 SE and T2, and hes got a 87 sport....its just freaky
Sideways7's Avatar
A phillips? I could see a flat-head maybe...
I actually locked my keys in the damn car today. Luckily I had the door panel off so it was easy to jimmy the lock.
Old Jul 24, 2006 | 07:56 PM
Skiles2070's Avatar
perrty lil rotory
yeah that does suck but I had some jack *** with a flat head screw driver unlock and disarm the alarm and stole all my cds and 2 speakers. so we should probly keep this kind of info on the down low!
Old Jul 24, 2006 | 08:19 PM
beamer242's Avatar
wow i didnt know this till today, but i guess mine isnt that bad on the lock. my key wont even unlock it easily... haha.
Brian
Old Jul 24, 2006 | 08:22 PM
86TwinTurbo's Avatar
haha my lock on my glove box is stronger than my door lock
Old Jul 24, 2006 | 08:26 PM
Radial GT's Avatar
*BOV sound*
And than there is the pleasure of trying to unlocking your car in january -15F after you washed your car earlier that day. HAHA not even a slim jim will unlock it, muhahaha!! Take that would-be thiefs!
Old Jul 24, 2006 | 11:02 PM
rick_tj's Avatar
My '87 T2 key and '86 n/a key don't seem interchangable between each other.
Old Jul 24, 2006 | 11:25 PM
Icemark's Avatar
bunch of ignorant people here in this thread. :shakes head:
As covered countless times... (yep I guess we have to do it again)
The only reason the lock is able to be unlocked with anything but the factory correct key is because the locks have not been properlly maintained.
If the lock cylinder is clean and properlly lubed. There is never the problem of the wrong key opening the car.
See the lock cylinders get full of crap and dirt. The tumbler keys stick in the unlocked postion so that anything will turn the key cyl.
clean your locks out instead of talking crap. If you or the last owner maintained them, you wouldn't have the problem isn the first place.
And finaly the odds of a factory key duplicating on the FC is 1 in 20,000.
Old Jul 24, 2006 | 11:35 PM
vipers's Avatar
IIMMM BBAAACCKKK!!
is there a way to clean them out after the damage is done? like sticking lube on the factory key and sliding it in and out? or pulling the ignition out and soaking it in a solution? (minus the electrical components)... because every rx7 ive owned has had this problem.. and now that im investing all this money into my car, the last thing i want is someone to just come up and drive off w/ my car because their key fit....... if you say it cant be done, then im just gonna buy a brand new key lock set from mazda....
Old Jul 24, 2006 | 11:46 PM
Icemark's Avatar
If the damage has already been done and they are locked up you best bet is to remove the key cyl and spray and spray and spray a degreaser/cleaner into the cyl alternating with putting the key in and out to loosen everything up.
Once it is all loosened then clean out and spray in a dry lubricant (like spray graphite or spray silicon). DO NOT USE WD-40, TriFlo, or any simular wet lubricant. It will only gum the whole thing up again. Dry lubricants only.
Old Jul 25, 2006 | 12:03 AM
raptor22's Avatar
Mine is pretty bad, too. Mine has some teeth missing one one side but works fine.
--Alex
Old Jul 25, 2006 | 03:01 AM
MaczPayne's Avatar
Mac Attack
I cleaned/replaced my lock cylinders, and have no problems with other keys as of yet. Of course, it's not like someone would steal my car, it looks stolen already.
Coochas
Oct 3, 2015 04:49 AM
rotor_veux
Sep 28, 2015 09:25 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
