Greddy B-spec 2 settings
Old Jul 24, 2006 | 10:39 AM
13bturbofc's Avatar
mmm doritos
I bought this boost controller hoping it would be alot nicer then the manual turbo xs model i had before but unfortunatly i cant figure the damn thing out ive read the instructions over and over and they made this thing so complacated i hate it maybe im just stupid though so im sure many others have this same boost con. can anyone help explain the functions on this thing? (what # settings do u have for what amount of boost)
Old Jul 24, 2006 | 11:33 AM
J-Rat's Avatar
Alcohol Fueled!
OMG. I sold that bitch so fast.. Hated that thing.
Here is the functionality for you:
Start boost: this is a number in PSI or BAR (depending on your settings) that the Profec wil start opening the wastegates. This allows you to hold the gates closed as long as you can before they open for better spool.
Gain: This is a number in percentage, that tells the Profec how fast or slow to regulate the wastegate.
Set boost: This is a number in percentage ABOVE your base boost, that you want.
If you have ANY boost creep issues, then that Profec will play hell with you. Good luck!
Old Jul 24, 2006 | 11:52 AM
The Wankler's Avatar
FKITALL
I have kinda figured mine out. No boost creep. But now, almost turned off, I still go past 11psi..... I dont want that!
However, spoolup is extremely fast!
Old Jul 24, 2006 | 03:23 PM
13bturbofc's Avatar
mmm doritos
thanx for the help J-RAT im gonna try to mess with it some more and if i cant figure it out im gonna sell the peice of ****! what r u running for a boost controller now? any sujestions on a good boost controller thats a little easier to use and adjust?
Old Jul 24, 2006 | 04:46 PM
J-Rat's Avatar
Alcohol Fueled!
I said "**** it" and put an MBC in. I am going to probably get the new Greddy one thats more like the old school one.
Old Jul 24, 2006 | 04:55 PM
FKITALL
everyone does tend to bitch about these. I refuse to give up, but do worry about the boost past 11psi right now. Even with my "Start Boost, "Gain Boost" set to "O", I still blow past 11psi.
streetlegal?
Mar 17, 2022 02:46 PM
Snoopy FD
Dec 8, 2015 01:45 PM
