my car is magic?! (fixed it self, sort of)
Old Jul 23, 2006 | 03:40 PM
ultrataco's Avatar
r o t a r y
Talking my car is magic?! (fixed it self, sort of)
I had been smelling gas when I drive my 91 n/a. Yesterday, I changed my oil and oil filter. This morning, I started it and noticed something leaking out the bottom and then I saw something spraying out from the general direction of the oil filter. I didn't leave the car running long enough to see where this stuff (not sure what it was) was coming from. I tried to tighten the oil filter, and it seemed tight.
A few hours later, I started the car again and... no leaks or anything. I let it warm up. still no problems. I drove it about 10 minutes into town and back. About 5 minutes down the road, I realized that I couldn't smell gas any more. My check engine light also didn't come on like it usually does after about 15 minutes.
After having my car for 3 weeks, I have only one more problem to fix: the rough and slightly high idle. I haven't even tried to fix it yet. first i'll just try the screw on top.
I assume the leak was oil, and the filter just wasn't on tight, but I don't know why my car doesn't smell like gas any more. (It wasn't really strong, but it was there)
Old Jul 23, 2006 | 04:29 PM
ultrataco's Avatar
r o t a r y
i should mention that I believe the oil that was in the car was valvoline 10w30 that had been there too long, and a fram oil filter. I put in castrol gtx 20w50 with a mobil 1 filter.
Old Jul 23, 2006 | 04:36 PM
wolftickets's Avatar
my car smells like gas all the time, its running rich baby rich.
Old Jul 23, 2006 | 08:42 PM
ericgrau's Avatar
Clean.
My car smelled like gas before... it had a leaky fuel pulsation dampener! Got it fixed. It's a major cause of engine fires in RX-7's. It's over the exhaust manifold and under the intake manifold. If it drips gas on a hot exhaust manifold, you get a fire.
Old Jul 23, 2006 | 11:34 PM
Enthu's Avatar
Still has an RX7.
You better check your FPD!!! You may not be able to always smell the fuel when it leaks. If you're smellign gas, you need to knwo whereit's comign from... could just be you are running rich. It's just that I had an intermittent fuel smell and ended up find my FPD to be dripping alot of fuel.
I've never tried a Mobil one filter.. wonder if it's worth it? Myself I use purolator Pure One MX-6 size. It has the Anti-drainback valve and you really should have it since the filters inverted on our cars. The Mobil 1 probably has too though.
Old Jul 24, 2006 | 12:02 AM
Secondmessiah's Avatar
Rotary enthusiast
fram is a pain in the ***, on turboiis they are too big, and make it impossible to get them off (i have no clue how the previous owner got it on)
Old Jul 24, 2006 | 07:34 AM
Fc3s88rx7's Avatar
shouldnt use valvoline
use mobil or japanese imported oils
Old Jul 24, 2006 | 11:48 AM
darksider's Avatar
can yo name some good jappanese improted oil? thanks
Old Jul 24, 2006 | 01:22 PM
My5ABaby's Avatar
Rotaries confuse me
What, exactly, is superior about Japanese imported oils?
Old Jul 24, 2006 | 02:04 PM
riverzendz's Avatar
Interruptor Illuminada
Yep. Castrol GTX 20 50
Old Jul 24, 2006 | 02:15 PM
speed_monkey's Avatar
affen
mad JDM tyte yo haha
Old Jul 24, 2006 | 02:22 PM
carsaregood's Avatar
i've had an intermittent fuel leak/smell.
turned out to be an old fuel line, not my PD as i thought it might be. check your lines. you'll have to take off your intake manifold to get at those lines under there.
Old Jul 27, 2006 | 10:27 PM
ultrataco's Avatar
r o t a r y
After driving for a while, I can confirm that my check engine light doesn't come on anymore, which is weird because I had checked the codes earlier, and they had nothing to do with oil
Old Aug 18, 2006 | 11:57 AM
ultrataco's Avatar
r o t a r y
my cel came on again the other day. I think it has something to do the fan, because it only comes on after I've had the fan on a few minutes. I don't use the fan anymore, and I haven't seen my cel since the last time i had it on
Old Aug 18, 2006 | 03:49 PM
ra ra rotory's Avatar
Yeah, dude, Id check that pulsation dampener to make sure its not leaking. They are known to leak and cause engine fires. Not such an issue in 89+ cars.
And oil is oil for the most part. Use the recomended wieghts for your car and area as listed on the underside of the hood. Most oils that meet the GEL, or whatever those certifications will be fine. I recomend mazda filters.
Old Aug 18, 2006 | 04:36 PM
aznpoopy's Avatar
strike up the paean
fuel smell in car is no joke. don't write it off.
drive car, open hood, look for anything wet. check rubber lines, injectors, fpd, fpr, etc. anything that has gas running through it... CHECK IT!
gas + hot = fire
Old Aug 18, 2006 | 07:42 PM
Street_Knight's Avatar
Let's eat babies
mazdatrix has some GREAT japanese oil made specifically for the Rx7...
I say it's worth it.
But that's if your car is worth it.
Mine is...
Old Aug 19, 2006 | 09:50 AM
My5ABaby's Avatar
Rotaries confuse me
Mine is...
No...
Old Aug 19, 2006 | 03:56 PM
ProjectR13B's Avatar
No es bueno.
i hate vavoline. thats all my dad buys, BUT i put castrol gtx into the 7 =). and my car smells like gas too. i think almost everyones fc smells like gas honestly haha
tsmith94FD
Aug 16, 2015 05:41 PM
