Rear LCA bushing removal.
Old Jul 23, 2006 | 03:33 PM
F1blueRx7's Avatar
Couldn't stay away
Anyone got any tips? There are two bushings per side, and they each press in from the left and right sides, however, I cannot get them out. I've tried taking a flat head and catch the inside lip and then hit it with a deadblow, but no luck. Anyone have any exp with this ?
Old Jul 23, 2006 | 05:35 PM
u-looz's Avatar
HEAT ... you need lots of heat. a torch should heat the center steel so you can push it out ... then cut the rubber a little and that should push out also. use a spray lube to help with the rubber.
RaY358
Aug 19, 2015 11:44 PM
GrossPolluter
Aug 15, 2015 10:32 PM
