Cap or bypass heater core?
Old Jul 23, 2006 | 02:49 PM
Digi7ech's Avatar
I break Diff mounts
My heater core sprung a leak and is luckily draining more out of the car than onto the carpet.
I'm wondering if there woudl be any ill effects from capping the engine to firewall and firewall to radiators lines instead of just bypassing the core and connecting the two?
Running a coolant line around the engine would be teh suck compared to just capping them.
Old Jul 23, 2006 | 03:02 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
capping them willnot cause any problems.
i capped the lines comming off my cosmo re
Old Jul 23, 2006 | 03:43 PM
Digi7ech's Avatar
I break Diff mounts
That's the news I was hoping for!
No to buy some clamps and a few bolts to seal this puppy off.
Old Jul 23, 2006 | 04:01 PM
KingCobraV9's Avatar
Rotary engine victory
i wouldnt to this as a permanant fix tho the heater cor does more than just make your cab warm it will dissipate excess heat if your engine ever starts to get too warm.
Old Jul 23, 2006 | 05:29 PM
Digi7ech's Avatar
I break Diff mounts
only if you turn it on. Otherwise it shoudl be closed off.
I have my cooling system almost perfect right now.
It's been 114 outside and my temps wouldn't pass 195-200.
Old Jul 23, 2006 | 05:43 PM
eriksseven's Avatar
Make Money.
I had them capped off in my old s5 vert with no problems.
Old Jul 23, 2006 | 09:58 PM
Digi7ech's Avatar
I break Diff mounts
So do you really have to remove the damn dash to replace the heater core?
f so then this will probably be a perm fix becaue a dash removal wopuld be teh suck.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
