8000 rpm coldstart ?_?
Old Jul 22, 2006 | 08:04 AM
lupin's Avatar
Rupanrx
I just finished rebuilding my engine and I installed the s5 intakes and removed ps and ac. I'm using the alt relocation kit from pineapple racing. I also relocated my battery.
The car started and after a second reved to 8000 rpm(I don't know because my meters have no power) I had to pull the maf plug to shut her off.
The room fuse keeps blowing and I can't find the short, I have been confused by haynes wiring diagrams. I have found a few good ones online.
and I didn't have a proper gasket for my thermostat neck so coolant was spray out.
So then I unplugged my alternator and the car doesn't seem to have any power.
I need help -_-
edit: I forgot to say that the headlights work, hazzards, turn signals, and the dimmer but the gauge needles don't move
(but now that I unplug my alt nothing works but there is power coming from the battery)
Old Jul 22, 2006 | 09:53 AM
lupin's Avatar
Rupanrx
i really need input guys
no one has any idea?
Old Jul 22, 2006 | 10:21 AM
arghx's Avatar
rotorhead
i'd check the throttle and cruise control cables if your car is just bouncing off the rev limiter like that.
Old Jul 22, 2006 | 10:24 AM
lupin's Avatar
Rupanrx
i unhooked them ^_^ for the second startup try
still went crazy
Old Jul 22, 2006 | 10:30 AM
classicauto's Avatar
Crash Auto?Fix Auto.
wierd man....could the TPS cause the ECU to load up the fuel if the TPS is waaaayy out of whack?
Old Jul 22, 2006 | 10:34 AM
lupin's Avatar
Rupanrx
if it was floodingwith fuel it couldn't rev
it's got to much air
one of the throttle plates looked a little more open than it was suppose to be, I took off the tb and everything looked fine.
Now what if I didn't hook the coldstart vac lines correctly?
could that cause the engine to rev like that?
Old Jul 22, 2006 | 10:49 AM
I dunno, can the thermowax actually push the throttle far enough to reach those RPMs?
Old Jul 22, 2006 | 10:52 AM
Sideways7's Avatar
No. The fast ifle cam it controls only raises it a little.
Old Jul 22, 2006 | 11:04 AM
lupin's Avatar
Rupanrx
i wanna see what it does when it revs that high but I don't want to put my engine through that again
Old Jul 22, 2006 | 11:28 AM
FC3S Timmy's Avatar
ReTripleOG
thats dangerous your motor hasnt even broken in yet and 8k thats too much you can risk blowing it
Old Jul 22, 2006 | 12:13 PM
Dom_C's Avatar
vaccum leak
Old Jul 22, 2006 | 02:06 PM
lupin's Avatar
Rupanrx
captain obvious
Old Jul 22, 2006 | 03:41 PM
RotaryEvolution's Avatar
Sharp Claws
throttle linkage is bound up somehow. inspect the throttle plates, they should all be just about fully closed.
Old Jul 22, 2006 | 03:49 PM
ViperDude152's Avatar
Rotary Power Information
Ya your secondary plates shoudl be completly closed and your primary should be open only a hair. If your engine hits 8000 rpm, then something has to be wrong with the throttle body or the throttle linkage.
Old Jul 22, 2006 | 04:26 PM
SimplyComplex's Avatar
pfft.
Either that, or a vaccume leak. Had the same problem with my FD. Couldn't find the problem, but after I replaced EVERY vaccume line, it stopped.
Old Jul 22, 2006 | 04:27 PM
Sharp Claws
this is not an FD!
this is not a vacuum leak!
3rd gens use a MAP sensor not an AFM, HUGE difference..
Old Jul 22, 2006 | 10:15 PM
lupin's Avatar
Rupanrx
after closer inspection of things I had a vac line hookedup wrong -_-
I need a new filter neck gasket though and a thermostat from mazda
I will post more info when I get them
I fixed the wiring problem, I was a steve and hooked up four connectors wrong because it was hot as a bastard and I can be a steve sometimes
I like to say there ya go stevie
(rules of a steve)
if you think someone is stupid call them steve
if you don't know someones name call them steve
Refer to yourself as steve
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
musker
Oct 1, 2015 05:58 PM
