Am i ready for BNR stage 2 with my set up??
I'm still new and learning about turbos. I dont want to be another guy with a turbo upgrade and a blown motor! I want to make sure i have the support for a turbo upgrade. As i think i dont have the fuel or ECU yet for stage 3?
It does sound nice for $50 dollars more the get the stage 3,
Could i get one and just keep the boost down?? until i go Microtech, and upgrade the injectors???
Trending Topics
Your injectors are big enough. How big is that FMIC? Get a fuel pressure regulator, and make sure your clutch is capable of handling the HP. With your setup as long as the engine is fresh and u have the right amount of fuel with a decent FMIC u should be able to go stage 3 and boost 10 to 12 lbs. You will be making well over 300 whp. Remember the clutch tho as u will be burning a stock one VERY quickly with that setup.
