buzzer make it go away please
Old Jul 19, 2006 | 11:14 PM
stevie1020's Avatar
Gig a Giddy Go
my buzzer refuses to stop. on the idiot cluster no warning lights are going off i checked all of mine fluids they are all full. i did switch up S5 dash in to the car but everything works fine except i cant figure out one harness so i havent wiered it up yet. any help would greatly be appericated and sorry ahead of time for the crapy spelling
Old Jul 19, 2006 | 11:46 PM
Sideways7's Avatar
Well, depending on the harness, some of the sensors might not be hooked up right. I believe this could cause the car to think some of the fluids are low.
Old Jul 20, 2006 | 11:10 AM
13bturbofc's Avatar
mmm doritos
did the buzzer do this only after installing the new dash?if not you may have a bad coolent or oil level sensor i had that problem
Old Jul 20, 2006 | 11:41 AM
stevie1020's Avatar
Gig a Giddy Go
ya it only started doing this after i put the S5 dash in ill check the sensors thank you
Old Jul 20, 2006 | 03:21 PM
13bturbofc's Avatar
mmm doritos
u can check the sensors but if it only started after u installed the dash i wouldnt bother i would just focus on getting that harness all hooked up and go from there...im sure u can find a diagram somewhere here that should help you out.....good luck!
Old Jul 20, 2006 | 03:34 PM
ericgrau's Avatar
Clean.
If a sensor is unplugged it'll set off the buzzer. Probably not plugged into the harness, like people are saying.
Old Jul 23, 2006 | 12:17 PM
Icemark's Avatar
did you re-pin the harnesses??? If you put a S5 dash into a S4 car, you need to re-pin the wiring harness
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
jsesq
27
Sep 25, 2015 11:10 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
