Sponsored by: CARiD
Going to carb on a S4... what distributor
Old Jul 19, 2006 | 09:20 PM
onePOINTthree's Avatar
N/A is teh WIN!
hey guys i haven't been on here in a while but i picked up a S4 for $100 the other day and i'm turing it into a track only car and i'm planing on running a Weber 45DCOE side draught carb. My question is what distributor would I use with this setup? Would any 12A dizzy work? Any feedback would be a great help and to the search ****'s... i didn't find anything usefull
Old Jul 20, 2006 | 08:09 AM
rx7man13b's Avatar
I have a s4 also I carbed it side draught I use the stock ignition setup but I added the Jacobs fc1000 ignition to it. I connects real easy right between the cas and the Leading coil. Its only 180.00 shipped and it more than made up for the lost low end that happens when you pull the 5th and 6th port sleeves. Im not 100% sure if the 12a dizz will work I think it does though.
Old Jul 20, 2006 | 11:01 AM
N/A is teh WIN!
yeah i found out it does... i didnt know i could keep the stock stuff tho... intresting... you don't need to run teh MAF or anything?
Old Jul 20, 2006 | 05:22 PM
trochoid's Avatar
Old Fart Young at Heart
1st gen dizzy and coils. Check out the FAQs in the 1st gen sention. Jeff20B has a writeup on DLDFIS ignition. Cheaper, easy and performs as well as the high dollar aftermarket ones.
Old Jul 20, 2006 | 05:49 PM
No_Rotor_RX7's Avatar
if you want simplicity then go with the 12a distributor setup. you can run an msd box thru the cap on the leading side and you will spark strong enough to burn anything you can throw at it. if it's a track only car then you can simplify even more by just locking the distributor and have a total set timing.
Old Jul 20, 2006 | 06:49 PM
rx7man13b's Avatar
No you dont have to use the maf just the CAS
Old May 28, 2007 | 09:57 AM
ziig's Avatar
run a old school disy and a msd set up and some good magnor core wires and you should be goood..................
a jew
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
GKW
Sep 28, 2015 04:34 PM
