rear sway bar worth it?
Old Jul 19, 2006 | 02:44 PM
ToddFitz's Avatar
does a rear sway bar really help? and if so what can i expect to get from it?
Old Jul 19, 2006 | 06:19 PM
sar's Avatar
sar
Doin a rebuild.
The car has a stock rear anti-sway bar; with a larger aftermarket one you should expect more oversteer, and slightly less body roll. You should not need one for street driving unless you are overly dangerous in your turns/;ane changes. I don't think that a thicker one would help me much at the track I go to (Talladega Grand Prix), but I think there would be some significant improvement in autocross.
You should definitely upgrade the rest of your suspension before/with the sway bar including new shocks, springs, sway bar endlinks, and bushings - dtss removal should stiffen the rear significantly if worn.
Stephen
Old Jul 19, 2006 | 06:40 PM
Sideways7's Avatar
Only get one along with a stiffer front sway bar, otherwise it could really hurt the handling of the car. As mentioned, you should upgrade the rest of the suspention at the same time or before, too.
Old Jul 19, 2006 | 07:02 PM
ProjectR13B's Avatar
No es bueno.
if you plan on drifting i heard it helps quite a bit.
matty
Jan 18, 2020 10:39 AM
MazdaAspec
Sep 9, 2015 02:04 PM
need RX7
11
Aug 19, 2015 08:27 AM
