Bent subframe studs. Redrill or reseat?
Old Jul 18, 2006 | 07:41 PM
KamakazieX's Avatar
Question Bent subframe studs. Redrill or reseat?
I have bent subframe studs from a destroyed subframe from bottoming out on something. I finally got the old one out, I was wondering if I should redrill the holes to bolt into the new subframe or bend/replace the old studs back to place? I can't move them with any hand tools.
Id say the bolts are toe'd in about 1/2 in on the right and 1/4in on the left. Just the ones in the front. The rear bolts are fine and not bent at all.
Need some quick advice. Thanks in advance.
Old Jul 18, 2006 | 08:07 PM
Icemark's Avatar
Unless the studs are in the correct postion, the suspension will never be right.
So re-drilling would be out
Old Jul 18, 2006 | 08:47 PM
inflatablepets's Avatar
You are going to have drivability issues. Replace the subframe studs. I saw a thread on it and I think it was in the archives.
Old Jul 19, 2006 | 01:30 AM
iceblue's Avatar
Passing life by
well they are a long stud like a train track nail that is welded to the top of the lower control arm and goes all the way through it.
technicaly you grind the weld out and pop it out.
Old Jul 19, 2006 | 03:39 AM
Carzy Driver's Avatar
Law Breaker
This thread was in the archives and is basically what you need to do:
https://www.rx7club.com/2nd-gen-archive-72/how-replace-broken-subframe-bolt-518333/
hope it helps.
Dave
Old Jul 22, 2006 | 06:09 PM
KamakazieX's Avatar
The bent studs are the two right at the front wheel wells, the 2 most front to the car, how do I realign them. The spacers inside the frame rails have been bent bent thats what I meant to ask. The studs are fine, but they just got knocked in a 1/2 in about on each side, redrilling wont work? I dont have a grinder, or access to a welder.
Old Jul 22, 2006 | 06:11 PM
KamakazieX's Avatar
I figured if i used a caliper and got the angle of the stud misalignment I could match it to the mount holes in the front end and grind it out a small bit. The rear two studs are fine.
Old Jul 22, 2006 | 06:20 PM
KamakazieX's Avatar
This would impact my front end alignment? What about the adjustment sleeves on the steering rack?
Old Jul 22, 2006 | 11:43 PM
iceblue's Avatar
Passing life by
thre is 2 on each rail. Replacing one of them will not affect your suspention. It only holds the sub frame up. If you have 3 still and you grind one out you can seat a new one bolt it down and weld it back on. Repeat on other one.
Old Jul 23, 2006 | 05:32 PM
KamakazieX's Avatar
Im not sure I explained it right, The studs aren't bent, the bottom of the rail is and the spacers inside the rail are.
Old Jul 23, 2006 | 10:15 PM
iceblue's Avatar
Passing life by
buy a new sub frame
Old Jul 24, 2006 | 11:55 AM
Originally Posted by iceblue
buy a new sub frame
+1
I guess u didn't explain very well either.
Old Jul 24, 2006 | 03:15 PM
13bturbofc's Avatar
mmm doritos
sounds like you may need a trip to the body shop to get that thing on a frame machine and make sure everythings in spec
Old Jul 25, 2006 | 04:03 PM
KamakazieX's Avatar
I just tried to put up the new subframe, i cant get it to line up, id say its off about a 1/2-3/4's of an inch too far apart on the rear studs, the front about 1. I'm stumped like hell and need some help, I'm trying not to junk it.
-Thanks in advance..
Old Jul 25, 2006 | 07:09 PM
KamakazieX's Avatar
bump.
any suggestions, its not really in running condition to get to a body shop..
Coochas
44
Nov 5, 2019 11:08 PM
Devon300zx
Sep 22, 2015 12:07 PM
