Pulling rats nest
Old Feb 21, 2002 | 04:10 PM
79+80_rx-7's Avatar
Pulling rats nest
Can I pull the rats nest, with stock everything??? Air pump gonna be removed to, then do Icut the exaust at the header???? If I dont have avc (or whatever)block off plates, then can I still do it? THANKS
LATERZ,
Andrew
Old Feb 21, 2002 | 04:16 PM
RXcetera's Avatar
EliteHardcoreCannuckSquad
How many times will this question come up?? SEARCH for RATS NEST!!!!
Old Feb 21, 2002 | 05:16 PM
Directfreak's Avatar
I am a Jeeper Now.
Thank you!
Old Feb 21, 2002 | 05:29 PM
peejay's Avatar
Old [Sch|F]ool
I wouldn't tear everything out until you find out what your problem is first. Otherwise you could just be compounding problems.
And don't remove the air pump or rat's nest unless you're also installing a header at the same time, otherwise you WILL destroy your thermal reactor.
Old Feb 21, 2002 | 06:10 PM
79+80_rx-7's Avatar
I was going to cut everything off from the haeder back! Or is the thermo reactor attached to the header? THANKS LATERZ
Old Feb 21, 2002 | 07:14 PM
peejay's Avatar
Old [Sch|F]ool
The thermal reactor is basically the exhaust manifold... bolts right to the engine.
Old Feb 21, 2002 | 08:46 PM
79+80_rx-7's Avatar
Dam! Back to the drawing board. Well, guess I am gonna have to make the header as planned. Unless one of you have on CHEAP! oh well LATERZ,
Andrew
msilvia
164
Mar 8, 2020 08:00 PM
FbFuninthesun
Oct 6, 2015 08:03 AM
