Sponsored by: CARiD
mount engine on stand without adaptor?
Old Jul 11, 2006 | 04:40 PM
calrx7's Avatar
aim** JI II IM IM Y
I have an engine stand from harbor freight but I do not have the adaptor for the rotary engine yet. Would it be possible to mount it on the engine stand to store it temporarily until the adaptor arrives?
Old Jul 11, 2006 | 05:30 PM
13b4me's Avatar
Not really... Just be safe and get the adapter first...
Old Jul 11, 2006 | 07:17 PM
89gt-x's Avatar
ive done it a couple times via the flywheel and bailing wire, i wouldnt recommend it, the adapter is way better/faster/safer..
Old Jul 11, 2006 | 07:44 PM
HeffBoost's Avatar
Keep Right Except to Pass
A piece of 3" channel works just as good as any adapter.
Old Jul 11, 2006 | 08:25 PM
MrFC3S's Avatar
ROTARD FOR LIFE!!!
Wheres the cheapest to get the adaptor?
Old Jul 11, 2006 | 08:27 PM
NeCr0mStR's Avatar
I just wanna hump my car.
I'll let you borrow mine if you pay shipping.
BUT I do want it back when your done I will pay shipping for return.
Old Jul 11, 2006 | 08:55 PM
user 893453465346's Avatar
Red Pill Dealer
How handy are you? I made mine from flat stock. Used a piece of 1x2 bar for a spacer.
Old Jul 11, 2006 | 09:00 PM
rotarygod's Avatar
Rotors still spinning
I've mounted several engines to a stand without an adapter. It's easy and yes you can assemble them this way too. You still mount to the front housing of the engine. If you are not building an engine and just want to hold it on a stand, you mount it from the transmission bolt holes at the rear. You don't need an adapter. You just need to look at it a little while to figure it out.
Old Jul 11, 2006 | 09:57 PM
Fire85GSLSE's Avatar
Chad Carson
I agree, we have built several motors using the stand only. We remove the Side bracket just infront of the sparkplugs (hold ps or ac unit) and remove one of the studs and mount there using bolts and one factory stud. Works great and is easy to teardown or reassemble.
Old Jul 12, 2006 | 12:59 AM
trochoid's Avatar
Old Fart Young at Heart
All you need to do is remove the studs that hold the ps/ac bracket on the front iron and get long bolts to go through the holes on the mounting arms of the stand. You may need to add some washers on the engine side to get clearance so you can rotate the engine during teardown/assembly. No bracket, adapter or angle iron needed.
Old Jul 12, 2006 | 02:04 AM
rotarygod's Avatar
That's exactly it but I've actually still used 2 of the stock studs. No spacers. One simple thing to do that no one ever mentions is to just drill a new hole in the mounting plate.
Old Jul 12, 2006 | 07:27 PM
bl0d's Avatar
Anybody got pictures of the engine on the stand without the adapter? I'm sure i can figure it out from what you've said, but it's always easier if i've seen it.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
