Idle at 4k
Old Jul 5, 2006 | 11:23 PM
jkstill's Avatar
Searching for 10th's
Idle at 4k
After replacing the LIM gasket on my 3rd gen, the hunting idle has disappeared.
It has been replaced by an idle that is way too fast.
When the coolant temp hits about 185 degrees, the idle jumps immediately to 4000 RPM. The idle speed prior to that is about 1700.
The TPS voltages as read on the PowerFC commander are just slightly out of spec, about 0.06 volt.
I will adjust them within spec, but need to know what else I should look for.
What part of the idle system would cause the idle to jump to 4k and stay there when the car gets up to temp?
This is a single turbo car, stock motor, with Power FC.
FWIW, I didn't do the single turbo conversion, so I'm not sure what all changes were made to go single turbo.
Old Jul 6, 2006 | 12:27 AM
cewrx7r1's Avatar
Eye In The Sky
It is obious that you either have a large air leak, your throttle is sticking open, or something with the throttle body if FUBAR.
Start being a mechanic, or take it back to the people who did the conversion.
Old Jul 6, 2006 | 12:29 AM
jamespond24's Avatar
I had the same problem before and it turns out to be either the brake boost hose or the oil neck hose.
Old Jul 6, 2006 | 12:53 AM
charlies7's Avatar
3rd rotors a charm
i know if you did the throttle body coolant deletion mod can casue a high idle if you dont wire the open...i could be wrong though... just a thought, someone add.
Old Jul 6, 2006 | 01:01 AM
jkstill's Avatar
Well, it might be obvious if you know what to look for.
The throttle is not sticking open.
Large air leak? Maybe, but not too likely at this moment, as the gaskets have all just been replaced. The large air leak was causing the hunting idle, which is now gone.
(1500-3500k)
Take it back to the guy that did the conversion? Not an option, out of business.
Become a mechanic: that's what I'm doing, and why I'm asking for help.
Any more helpful suggestions?
jkstill's Avatar
4k idle
Thanks, I will check those.
Old Jul 6, 2006 | 01:02 AM
jkstill's Avatar
Thanks, but the throttle body coolant lines are still there.
Old Jul 6, 2006 | 01:06 AM
It's got to be somewhere after the TB and before the LIM.
Old Jul 6, 2006 | 09:48 AM
cewrx7r1's Avatar
Eye In The Sky
DAPDAS^2
Old Jul 6, 2006 | 12:23 PM
jkstill's Avatar
The problem turned out to be 90% TPS adjustment, 10% Fast Idle Adjustment.
Obviously not an air leak.
Old Jul 8, 2006 | 04:44 PM
cewrx7r1's Avatar
Eye In The Sky
I think you have your percentages reversed. OK tell us what you really did.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
