Klunking noise when aggressively shifting!
Old Jun 29, 2006 | 10:56 AM
TimsR1's Avatar
Please help me out.
When driving normally or shifting normally I have no noise or problem. When shifting aggressively I get a "klunk' in what seems like the rear under the car.
I would like to narrow the problem down so I can go on with my summer. It has been suggested that it is the PPF (power plant frame) being cracked or damaged. It has also been suggested to be a bushing in the rear of the car above or behind the differential.
Any suggestions or confirmations of what the problem could be?
Maybe someone out there has experienced the same problem and has remedied it.
Any advice or suggestion are welcome and will be checked out and fixed if found to be the culprit. Maybe I'll just change/fix all suggested issues and hope for the best?
Thanks in advance,
Tim
Old Jun 29, 2006 | 11:19 AM
Doncan's Avatar
No doubt, It's the differential bushing. It's purpose is to act like a bump stop.
Old Jul 15, 2006 | 10:35 AM
Kaotic Dan's Avatar
I had this same problem. Is your shifter moving around alot with throttle changes? If so it is definatly the PPF. I checked it for cracks without removing it and didnt see any, so i replaced the diff and motor mount bushings to no effect. When I removed the PPF to do the diff bushings I noticed a huge crack. Replaceing it solved the problem. Before replaceing your bushings remove the PPF and inspect it for cracks, it may save your alot of time and money.
Old Jul 16, 2006 | 06:46 PM
Chief_MC's Avatar
Sorry for stupid question, what is PPF?
Old Jul 17, 2006 | 06:40 AM
maxcooper's Avatar
WWFSMD
That is an FC part. I think the OP is talking about an FD.
PPF = power plant frame = thing that connects the front of the diff to the end of the tranny on an FD.
-Max
Old Jul 17, 2006 | 10:53 PM
rexaholic's Avatar
could it be your sinchronizers on your tranny?
Old Jul 18, 2006 | 05:05 AM
Chief_MC's Avatar
No, symptoms for synchros are different
Old Jul 18, 2006 | 09:19 PM
Funkspectrum's Avatar
u-joints?
renjiv2
57
Jan 25, 2024 03:34 AM
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
