Power FC More Boost
Old Feb 19, 2002 | 05:27 AM
daze's Avatar
Question More Boost
Hi, im new to PFC and I was wondering how can i turn the boost up with the commander? Thx
Currently have dp, exhaust, and intake. searched around the forum and found out I can boost 12 psi. Is that right?
Old Feb 19, 2002 | 07:42 AM
cewrx7r1's Avatar
Eye In The Sky
If that is all the mods you have on your engine, even with proper PFC tuning, going higher boost is not a wize decison. In order to force more air into an engine, you also have to be able to get it out. The stock cat is too restictive , and it would be safer to have a larger IC. You also should have an upgraded cooling system.
Some have run over 12PSI with a close to stock system, but I wouldn't.
Old Feb 19, 2002 | 10:43 AM
cewrx7r1's Avatar
Eye In The Sky
Clarification to my prior post, what I meant was 12psi was OK but do not go over it with your current setup.
Old Feb 19, 2002 | 02:03 PM
daze's Avatar
thx but can you explain to me how to use the PFC to turn up my boost?
Old Feb 20, 2002 | 11:09 AM
cewrx7r1's Avatar
Eye In The Sky
I do not use it, but the manual briefly explains it on page 27.
There are two sets of boost control maps that you can set up and switch between. Each has a pair boost settings and a duty cycle settings. Values are for primary and secondary turbos. You set the boost level for these to what you want to run, and a start point for the duty cycle. Lower cycle for lower boost. Make runs and watch the boost level.
If the boost is too low after a few run, increase the duty cycle value.
Someone else should be able to describe this better than me. Also do a search on this forum as this has been discussed before.
Old Feb 20, 2002 | 12:22 PM
Jodeny's Avatar
Indifferent
You can safely boost to 14-15 pounds in cold weather and I wouldn't go over 13 in hot weater.
John
Old Feb 20, 2002 | 09:41 PM
daze's Avatar
thx again!
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
