Haltech haltech e11v2 firmware upgrade
Old Jun 19, 2006 | 01:55 AM
funklove's Avatar
In rotor we trust!
Guys, where I can get 1.29 firmware ?
Is 1.62 software less buggy than 1.59? I use 1.59 now and I have some problems with this soft:
1) Often I see different error windows, program do not work stable
2) The A/F ratio settings is integer (like 14), but my LC-1 generate real datas (like 14.35). And it is difference about 0.1-0.2 A/F ratio between haltech read and gauge read.
3) I can't read O2 log. I think cose data log viewer expect integer variables of A/F.
Old Jun 19, 2006 | 12:07 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Just email Haltech for the latest B29 firmware which goes with Software version 1.62.
Old Jun 19, 2006 | 06:44 PM
13BT510's Avatar
software
The newer software may not have the bugsyour talking about ironed out.
I notice you in russia - make sure your laptop mode is set to metric or US, little things like the decimal place and the comma symbol are used differently according to what country your laptop is setup as and can cause these sort of errors...especially in the datalog.
Old Jun 19, 2006 | 06:55 PM
EFI Tech Wannabe
Oh! good call, dang, russia, far away... Thats good advise, you should set the keyboard and regional settings to US, cause apparently they are developed for english configured machines, so the software tends to go bezerk when you have something different.
Old Jun 20, 2006 | 01:47 PM
funklove's Avatar
In rotor we trust!
Thank you, U are right. I solve this yesterday.
Old Jun 20, 2006 | 02:05 PM
funklove's Avatar
In rotor we trust!
Other problems:
I connect LC to E11's AD1 and play.
1) I can't change sample rate in Halwin logger (data that's recive on comport)
2) I suspect that my LC-1 gauge and LC logger (digital) show difference between Haltech O2 readings. Settings are ok.
3) I can't save O2 settings in halwin. I see it, but if I choose haltech o2 I loose it.
4) Halwin reads 1 digit after point, and I can set only integer AFR settings. It's enought, but offensively by the way.
But haltlech customers service is nice I recived upgrade today.
I keep on look at haltech
Old Jun 20, 2006 | 03:17 PM
EFI Tech Wannabe
Usa SpareA/D 3 for the UEGO. The program has that input or the O2 sensor input set for that duty.
You change the sample rate on the Fuel Setup page. Then, when you connect to the Haltech you view the AFR in the Dataloggin Options.
Old Jun 20, 2006 | 04:55 PM
funklove's Avatar
In rotor we trust!
Thank you Claudio and other guys for advice!
ls1swap
Jun 3, 2024 03:25 PM
