Sponsored by: CARiD
New LSD need some help!
Old Jun 11, 2006 | 11:38 AM
jimmytango00's Avatar
i recently bought an 89 gtu witha 13bt motor in it. ...Finally got around to getting an LSD for it and me and my friend (whos installing it) are having some problems. When they put the driveshaft back on and torqued it down to the diff. it was really stiff. We found out theres a certain amount of pounds its supposed to be torqued, does anyone know how much? and should i just keep the drifveshaft the gtu comes with or buy a turbo 2 driveshaft?
Old Jun 11, 2006 | 12:06 PM
anyone?
Old Jun 13, 2006 | 10:21 AM
kungfuroy's Avatar
Chicken Adobo
All the hardware( nuts/bolts) you removed needs to be torqued down to a specific setting. The torque specs are in the FSMs which can be downloaded through the links in the 2nd Gen FAQ stickie, or you can get the settings from a Haynes manual which can be obtained at most auto parts stores for <$20. Are you sure you have the right combo of parts?
You say the car has a 13bt, does it have the turbo transmission, driveshaft, diff, halfshafts?NA and turbo drivetrain parts dont mix.
Old Jun 17, 2006 | 08:37 PM
thanks for the reply.. i got my car together and its up and running ...all i was missing was the driveshaft wich i found...now the whole D/T is turboII
Josh83rx7
Oct 2, 2015 07:13 AM
Josh83rx7
Sep 24, 2015 11:47 AM
