Max boost on pump gas?
Old Feb 17, 2002 | 09:57 PM
yy4u's Avatar
HI i was wondering what the mazimum amount of safe boost is on pump gas. Does it vary from car to car? I'm running a t-78 and have upgraded just about everything, see my signature, for specifics. Just wondering what the max boost i can run with my current setup on 93 octane pump gas, without worrying about detonation.
Old Feb 18, 2002 | 01:47 PM
AARotary's Avatar
My best guess would probably be anything under 20psi and anything above it you are asking for detonation.
Old Feb 18, 2002 | 02:45 PM
JoeD's Avatar
20 is a little too much on pump gas, IMO.
on 93 pump, even with very good tuning, i wouldnt push it past 17 PSI. anything more than that is just asking for trouble.
Old Feb 18, 2002 | 03:38 PM
VTECthis's Avatar
Apexsealistically Chalngd
I dont care how much boost you run, ALWAYS worry about detonation, you can detonate at 1psi , but seriously, run 15-17 psi, and turn it down a bit in the colder weather.
Rob
Old Feb 18, 2002 | 09:17 PM
yy4u's Avatar
thanks for the info guys. special thanks to gordon, i appreciate you taking to the time to supply all that info, it was a big help. Any other opinions are appreciated, and yes i am running stock 550 primaries.
THanks again-
-Rob
Old Feb 18, 2002 | 09:42 PM
94touring's Avatar
I've been running 18psi on pump gas for quite a while now with no problems. Its all about tuning and air fuel ratios.
Old Feb 18, 2002 | 10:40 PM
Bacon's Avatar
IRS 4 Life
with 1200cc secondaries i wouldnt push 15-6psi
ive seen people with 1600's only run 18 max on pump94
but with pfc youllneed new map to run over 17psi,
gordon-well said man
Old Feb 24, 2002 | 06:42 PM
newRX7fan's Avatar
My advice is to keep on increasing boost until your engine blows, then back off 1 or 2 psi.
Old Feb 24, 2002 | 07:37 PM
JoeD's Avatar
doesn't sound like very good advice.
Old Feb 24, 2002 | 07:51 PM
peejay's Avatar
Old [Sch|F]ool
My car used to detonate at anything over about 5" of vacuum!! (rough guesstimation)
Tuning, no matter how bad, or good, combined with your porting etc., is the key,
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
CaptainKRM
15
Aug 29, 2015 01:33 PM
TerryD
Aug 23, 2015 07:40 AM
Wolf_
Aug 11, 2015 04:23 PM
