Airbag removed, How do I get rid of the Beeping...Oh God the Beeping!
Old Jun 5, 2006 | 07:40 PM
ecarver2's Avatar
local Celebrity
Question Airbag removed, How do I get rid of the Beeping...Oh God the Beeping!
I have no airbag. Please help me. It beeps a couple times, fivetimes over. I cant stand it, it must be stopped!
Old Jun 5, 2006 | 08:28 PM
axr6's Avatar
I don't remember beeping when I removed my air bag/steering wheel. The air bag light did come on. To get rid of that I could either insert a straight jumper wire between the two connectors that used to connect to the airbag or, if the connector wire harness was removed at the connectors under the steering column, insert a 1 ohm resistor into the same two wire connectors.
that should make the system "sense" the presence of an airbag.
Albert
Old Jun 5, 2006 | 08:45 PM
ecarver2's Avatar
local Celebrity
my car had the whole steering colum and clock spring removed, it was kindof micky moused.
Old Jun 5, 2006 | 09:59 PM
axr6's Avatar
Ok, if you had the clockspring removed you will need a 1 ohm resistor placed across the connector terminals under the steering column. The terminals are those that the air bag used to connect to. When I did mine, I did not have a 1 ohm resistor. I simply used an about 8" length of welding wire that came close to being 1 ohm. I cut off the connector as I saw no real good way to attach my wires to it and installed a pair of spade type connectors on each wire. I wrapped the wire in heat shrink and coiled it up under the steering column cover.
Albert
Old Jun 5, 2006 | 10:57 PM
ecarver2's Avatar
local Celebrity
I was thinking more along the lines of where is the frickin box that beeps and whats the best way to remove it. I have not really looked for it yet. I was just fishing around for sme past experience.
Old Jun 6, 2006 | 09:05 AM
DaleClark's Avatar
RX-7 Bad Ass
Yeah, just find and unplug the airbag computer. Follow the beeping sound .
Dale
Blastfastrotary
Sep 11, 2015 12:26 AM
ls1swap
15
Sep 8, 2015 05:30 PM
