Eastbear ISP VS Hella Upgrade
Old Feb 17, 2002 | 10:38 AM
manatecu's Avatar
Hey guys what do you think. Should I cut a little out of the lighting frame to get the hellas to go back and sit like the ISP's (Orginal Lighting with East Bear Kit), or should I just stick with the east bear lights. Note: The Hellas are incredible the ISP's are OK, kinda spotlighteeeee.
Thanks
Chris
manatecu's Avatar
another
Old Feb 17, 2002 | 10:40 AM
manatecu's Avatar
another angle
Old Feb 17, 2002 | 10:41 AM
manatecu's Avatar
Last Angle
Old Feb 17, 2002 | 11:50 AM
rx7tt95's Avatar
Photo Diety
How much trimming is necessary to get these lights to sit flush and just how hard is it going to be? I don't think it would look all that bad as is on a black car, but once you paint the kit, it may look like poop with the black showing against the red background.
Michel
Old Feb 17, 2002 | 01:04 PM
manatecu's Avatar
What I would need to do is pull the lights back to the edge of the housings. I would then put some type of filling material in the holes. I was thinking of rubber but I could use some reflective type of material. I was also thinking about rubber like a gasket and then Demon lights around the light housing itself.
Chris
Old Feb 18, 2002 | 02:25 AM
spyfish007's Avatar
Yellow Dragon is no more
Have you thought about adding some fiberglass to extent farther forward to cover the Hellas?
Old Feb 18, 2002 | 04:47 AM
LT1-7's Avatar
John
do the hella lights shine better than stock at least? I'm getting mine next week and I wanted to do the same thing. What color do those hella shine? I would paint the covers and see how they look first, they might be ok.
Old Feb 18, 2002 | 11:53 AM
manatecu's Avatar
I officially tried out the hellas last night. The H9 bulbs are awesome. I have a VW with HID's. There really isn't a whole lot of difference. I had my girlfriend line up both cars side by side on a dark road. Then burn both lights. The HID's had a slightly different color but as far as visability went they were the same. The Hellas have a beem that is very wide and long. If I were to draw it it would look like a "D" but with a 90 degree turn right. The original bulbs that came with the East Bear kit were OK but they were definately spot light looking. I would give the east bear lights a 6, Stock lights a 3, and the Hellas a 9.
I have decided to keep the Hellas, but I need to figure out how to fix the pod or the lights to make it look respectable. The diameter is roughly the width of a pencil all the way around. I was thinking about moving the lights back and using something, mabey the angel eyes to fill in the gaps.
I guess the bottom line is the Hellas with no lens restricting the light flow are very, very good.
If anyone out there is good at working with fiberglass and is willing to help let me know and we can work something out.
Chris
Old Feb 27, 2002 | 11:56 AM
legendrx7's Avatar
Rotarded since 1992
Damn! I thought the Hellas were the same size as the IPF's that come with the East Bear kit. I'm totally dissapointed b/c I was planning on putting the Hellas in as soon as possible.
Are they just bigger around than the IPF's? Do they fit in the mounting brackets of the East Bear kit?
BTW, I think it looks tacky protruding from the housings. They need to sit flush just like the IPF's.
Let us know what you come up with.
Old Feb 27, 2002 | 01:22 PM
manatecu's Avatar
Well as you can see below:
There is approximately a 1/4 inch hole around the lighting. I have put in both lights and I really, really like them, I just am going to have to cut a little to make them sit correctly. Yes they fit in the East Bear housings, but the light itself is longer, which cause it to stick out. I will post a picture later of what they look like currently. From the front I really like the look, but I agree I don't like the protruding. I am going to fix this I just havn't found the time.
Chris
Old Feb 27, 2002 | 03:10 PM
wptrx7's Avatar
Newb Photog
using fiberglass you can fill in the space and it will look exactly the same if done right. if you have not used fiberglass before it is really easy. pick up a tape from selectproducts.com this will help you alot ($40). this will also hold the lights in place and you can probably use back straps to hold in place. i know alot of people will disagree with that but if the back straps are attached properly (inbetween layers of fiberglass) they work miracles. then you have a flush look without having to move the lights back (maybe causing loss of light pattern.)
luigi
Old Feb 27, 2002 | 07:10 PM
manatecu's Avatar
Attached is what the latest looks like. Both lights are in and functional. They are just plain awesome as far as lighting goes. The low's need to be moved back about one inch and they will all line up perfectly.
Chris
Old Feb 27, 2002 | 07:11 PM
manatecu's Avatar
Or like this
Old Feb 27, 2002 | 07:19 PM
FourtyOunce's Avatar
since you are upgrading to the Hella DOT driving lights, wanna sell me the lights that originally came with the east bear kit? let me know - shoot me a PM.
Old Feb 27, 2002 | 07:30 PM
Mr. Stock's Avatar
1993 RX7 R1
Do you have the Hella low beam inboard of the high beam?
It looks like it in the pictures.
Old Feb 27, 2002 | 08:10 PM
manatecu's Avatar
Ya I moved the low beams over to the high beam location. Makes for better light seperation.
Old Feb 27, 2002 | 08:15 PM
NickSimcheck's Avatar
better light seperation and it looks a lot better to on coming traffic.
Old Feb 28, 2002 | 12:33 AM
spyfish007's Avatar
Glad to see moving the lights worked out!
Old Feb 28, 2002 | 05:17 PM
manatecu's Avatar
Here is what it looks like in semi-dark
Old Feb 28, 2002 | 05:19 PM
manatecu's Avatar
Both lights on
manatecu's Avatar
Yes they are as bright as they look.
Chris
Old Mar 3, 2002 | 02:50 AM
bladz311's Avatar
I just got my east bear kit today, and installed it. How much do the hella lights cost?? I like the east bears better than stock, but the hellas look much better
Old Mar 3, 2002 | 12:54 PM
lane_change's Avatar
It has begun
Does anyone have a pic of their FD with the East Bear kit painted and installed? I like the Hellas better but I would hate to mess something up by cutting the kit up to make them fit. Sounds risky to me.
Old Mar 3, 2002 | 01:32 PM
wptrx7's Avatar
Newb Photog
whats the website for the hella lights?
luigi
ls1swap
Jun 3, 2024 03:25 PM
