Sponsored by: CARiD
Engine cut around left hand corners
Old Jun 1, 2006 | 04:55 PM
hal9000's Avatar
Hi all, I think i'm at my wit's end with this thing, my 88 gtu auto-cross car has been cuting out around left hand corners, maybe right too but not as freqently. The first thing I did was check the tank, man it was a mess. droped the tank, put a new pump and sock in there, flushed the tank, made sure everything was clean sturdy ect. So I'm not thinking it's the tank. Also, the problem is very instantanious, I figure if it was durty pump sock it would be more proressive, this is like hitting switch. the engine is running great... then BAM gone, 2-3 seconds later, after the corner it comes back in like it never left.
Is there any electrical things that I might want to check out? It does not seem to smoke or backfire after it comes back in so I'm thinking it's not just that the spark is leaving. Is there a fuel cut/ role-over switch in these cars?
Thanks!
Old Jun 2, 2006 | 07:28 AM
My5ABaby's Avatar
Rotaries confuse me
Ummm, did you replace the in-tank fuel filter? Not sure if that's what you mean by sock.
Old Jun 2, 2006 | 04:50 PM
hal9000's Avatar
yep, thats the sock... there is also the in-line filter. thanks for the reply
Old Jun 2, 2006 | 10:04 PM
KeloidJonesJr.'s Avatar
strictly business
Yea, RE's are sharp.
Old Jun 3, 2006 | 12:28 AM
peachykeenwight's Avatar
marky
Same problem in my sister's '91 vert.. haven't found anything yet either.
Frisky Arab
13
Aug 18, 2015 05:30 PM
rx7jocke
Aug 15, 2015 03:36 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
