for RETed and anyone else who can help
Old Feb 16, 2002 | 11:22 PM
Agent_D's Avatar
rawr
i am about to buy a new engine to be street ported, would it be better to go with FD rotor bearings, and 3 window bearings, with a 100psi race/street oil pressure regulator and the thermo pellet block?? or should i just go with the thermo pellet block?? thanks for the help
Old Feb 16, 2002 | 11:28 PM
RETed's Avatar
Re: for RETed and anyone else who can help
Are you planning to spin it past 9kRPM or something?&nbsp If not, they are unnecessary.
You're talking about the front ecccentric shaft one?&nbsp If so, I highly recommend it for ALL FC's.
-Ted
Old Feb 16, 2002 | 11:30 PM
Agent_D's Avatar
rawr
ok thanks ted, i was planning to run only to 9k but not past 9k
Old Feb 16, 2002 | 11:34 PM
RETed's Avatar
If you're running the stock ECU, you can't get realy crazy anyways.
So a good rule of thumb is that if you're using the stock ECU, you don't need all the extra crazy bearings and stuff.
100psi oil pressure regulators are overkill on the street.&nbsp You'll get excessive oil smoke from all the oil bypass from the excessive oil pressure.&nbsp I recommend running the 80-85psi one for street cars!
-Ted
Old Feb 16, 2002 | 11:35 PM
Agent_D's Avatar
rawr
80-85, ok where can i find one of those racing beat have them??
Old Feb 16, 2002 | 11:41 PM
RETed's Avatar
Racing Beat would be easiest.&nbsp They are all basically early model OPR's that have been shimmed, so unless you know someone who works on old rotaries, RB would be your best bet.
-Ted
Old Feb 16, 2002 | 11:43 PM
Agent_D's Avatar
rawr
ok thanks for the help ted
Old Feb 17, 2002 | 12:10 AM
mazdaspeed7's Avatar
mad scientist
Ted, the FD oil pressure regulator bypasses at 80-85 PSI, correct?
Old Feb 17, 2002 | 12:12 AM
RETed's Avatar
Actually, it bypasses at 100psi - it's a bit too much for an FC.&nbsp If you DO use the FD OPR, remember to shim the front OPR in the front oil cover.
-Ted
paximus
20B Forum
14
Oct 2, 2004 10:11 AM
LS1FC
Aug 22, 2003 03:13 AM
No7Yet
Mar 2, 2002 02:42 PM
