RX-3 Lowering Leaf Springs???
Old May 31, 2006 | 05:51 PM
mannymazda's Avatar
MannyMazda
Question RX-3 Lowering Leaf Springs???
Does anybody have any idea how I can lower the rear leaf springs of my RX-3??? Need all the feedback I can get from the Rotary World! Thanks!
Old May 31, 2006 | 06:04 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
The absolute best way to do it is purchase some custom made composite leaf springs from these guys:
http://flex-a-form.com/
They eliminate axel wrap on acceleration, eliminate rear wheel hop under braking, and greatly help lateral axel control due to their thick mono-leaf design. Use axel shims between axel and leaf spring to change pinion angle if needed.
2nd best way is to take your leaf springs to a leaf spring shop and have them de-arched so they're perfectly flat. De-arching lowers the car AND eliminates rear roll understeer which is built into all leaf springs. And is caused when the rear eyelet in the leaf spring is higher than the front eyelet. Much better to Use traditional spring rates and sway bars to control under/over steer. Use longer rear shackels to bring ride height up to where you want it if needed. Use axel shims between axel and leaf spring to change pinion angle if needed.
3rd best way, and most common, is ghetto blocks. Lowers the car, increases axel wrap, but is cheap and easy. Use axel shims between axel and leaf spring to change pinion angle if needed. Some blocks come pre-angled to compensate for pinion change.
Worst way is to use shorter shackels, which is cheap, easy, but increases rear roll understeer, and makes the leaf rear eyelet change it's height very quickly under rear suspension compression. Which screws up the rear geometry and messes with rear suspension jacking, yuk. Use axel shims between axel and leaf spring to change pinion angle if needed.
Old Jun 1, 2006 | 03:44 AM
re10's Avatar
10a *****
Lowering blocks.
Old Jun 1, 2006 | 12:13 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
I didnt think you could run a flip kit on an RX-3 for some reason.
Old Jun 1, 2006 | 07:10 PM
SAVANT's Avatar
I SMELL GAS
That pretty much somes it up...
Old Jun 3, 2006 | 07:54 PM
mannymazda's Avatar
MannyMazda
Thumbs up Thanks Guys!!!
I appreciate all the feedback from all you dedicated Rotor Heads. After reading all that, I've decided to leave the rear the height that it is. It doesn't look that back actually. Really guys, thanks!!!
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
