Would changing out exhaust housing need a retune
Old May 31, 2006 | 04:41 PM
OneLongDong's Avatar
I was wondering if going to a small AR exhaust housing would cause the need for a retune. I was thinking maybe not but then since compressor maps would be different it might.
Old May 31, 2006 | 05:38 PM
dhahlen's Avatar
FD Under Construction =P
thats going to affect spool time. Therefore you'll be boosting in areas you normally didn't see boost before. Its going to need some adjustment.... If you had an experienced tuner - he could just quickly modify the map for the areas where the new setup will see boost. Otherwise you might run lean when the turbo comes on. But a fresh tune is always recommended.
Old May 31, 2006 | 06:55 PM
maxcooper's Avatar
WWFSMD
It changes the flow of the system, so it will change your A/F ratios while running. Whether it changes them enough to require a retune or not is a judgement call.
-Max
Old Jun 1, 2006 | 10:35 AM
pluto's Avatar
changing the housing is like changing to a different size tires for your car. do you need to recalibrate the speedometer for accurate speed?
Old Jun 2, 2006 | 02:39 AM
c00lduke's Avatar
Pluto I might face the same problem if I switch mine out and either dont have a chance to meet up with you in STL or all the spots fill up. Would fuel just need to be change or timing also?
Old Jun 2, 2006 | 09:10 AM
pluto's Avatar
timing for the most part should be okay but you really want the lowest timing at peak torque. your a/f ratio will be off for sure
FD7KiD
15
Feb 26, 2021 10:12 PM
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
