Knocking in the rear
Old May 31, 2006 | 01:18 PM
Exidous's Avatar
I moved the topic to this section because I wasnt getting much of a resonse from the suspension section. Thanks for your help in advance.
I have replaced the diff, pillow *****, diff mounts and trailing links. None of which were related to the noise however I thought it was important.
When driving down the road, smooth or rough, there is a rather continuous knocking noise in the rear. If I touch the brakes or e-brake the noise goes away. Let of the brake and it comes right back. Rather annoying. I have not replaced any other parts in the rear except for that listed above. Let me know what you folks think.
Old May 31, 2006 | 05:59 PM
Tom93R1's Avatar
gross polluter
Rear CV half shaft. Get down under there and grab each one and shake it to check for slop, I bet one of them is loose/worn.
Old May 31, 2006 | 08:16 PM
jeremyb's Avatar
Hi....
Did you replace all of the bushings back there also? Does it clunk when going in reverse? Check the U-joints on your drive shaft also.
Jeremy
Snoopy FD
Dec 8, 2015 01:45 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
