fuel cut of switch
Old May 30, 2006 | 09:40 PM
mickokeefe's Avatar
fuel cut of switch
Hi I'm mick and i just bought a 1988 mazda rx7 turbo 2
It has a fuel cut off switch installed and i know nothing about this and i am wondering if there is a way to make away with it or do all rx7's have them.
Old May 30, 2006 | 10:53 PM
KeloidJonesJr.'s Avatar
strictly business
It's called a fuel cut defenser . Two options: either make one or buy one. I believe Mazdatrix makes them.
Old May 30, 2006 | 11:17 PM
Juiceh's Avatar
Saiga-12 Power!
Um, you sure its not a manual switch to cut power to the pump? mickokeefe can you be a bit more specific?
Old May 30, 2006 | 11:56 PM
dhahlen's Avatar
FD Under Construction =P
Yeah details would be nice.
A fuel cut switch isn't typically used. Maybe the previous owner didn't wire his pump to the battery correctly (using a relay) so instead he used a switch and had to turn it on when he used the car??
Old May 31, 2006 | 10:59 AM
-=Lil Red=-'s Avatar
R.I.P. Guitarjunkie28
or if its hidden, it can be used as a theft detterent. no one can start the car without the switch
Old May 31, 2006 | 11:01 AM
RacerXtreme7's Avatar
NASA geek
My bet is its for unflooding a either high mileaged low compressing engine, or leaking injectors.
~Mike...........
Old Jun 3, 2006 | 06:13 PM
mickokeefe's Avatar
its a manual switch. The guy said it was to cut the fuel when starting when warm.when it's cold i can just turn the key and it starts.
alphawolff
Nov 17, 2015 05:57 PM
armans
Aug 15, 2015 09:08 PM
