Just got TII but my crank is soo low WHY??
OK i just bought a rx7 turbo and for some reason it crank slow and sometimes it wont start and it floods can this be a battery ive check the battery and it's good but it might have a low CCA OR can it be my starter That's what i think it is but am not a expert so can anyone guide me also it can't be the altenator it's new please help!
hook up a battery charger if you have one and try cranking with that on it. Sounds like it could be a battery issue depending on age of battery. Also do some research using the search button.
ok i have taken out my alternator,Starter, battery, took it to be checked and it works perfect all three! so i took it to someone and he told me it's flooding because of too much gas it's running to rich also i think the walbro fuel pump is connect directly to my alternator can all this be why my car is flooding all the time ( i have to take off the egi Inj relay and crank it like that then put it back for it to start up again ) any help please!
you could have leaky injectors, I think it talks about them in the faq.
And you should take out your spark plugs and clean them off after the engine floods. Pulling the egi fuse doesn't always work.
Adaptronic Cranking fuel table messed up?
sherff
Sep 12, 2015 12:22 PM
acha3
Sep 6, 2015 08:14 AM
