Installing Lowering Springs
Old May 27, 2006 | 01:04 PM
87_rocket's Avatar
gotNOS?
I searched high and low for a tutorial on how to install lowering springs, to no avail. I recently purchased some Tein Lowering Springs (1") for my 87' base (N/A) but i'm not sure how to go about installing them. Could someone point me in the right direction or give me a link to a guide? Thanks
Old May 27, 2006 | 01:17 PM
1SWEET7's Avatar
Now With 10th AE Fun!
Well it is pretty straight forward. You need to rent some spring compressors. When I did mine I just jacked up the front then put on jackstands. Take off the wheels. Compress your spring then take off the nuts holding the bushing on the strut tower. Then take off the bolts holding the old strut to the control arm. Replace in reverse order. Do the same for the rears. Good luck. Hope this helps.
Old May 27, 2006 | 01:55 PM
Phantomhp's Avatar
Well it is pretty easy but you will either need an impact wrench or a lot of pliars and another set of hands.
When you go to loosen the nut that holds the top spring mount on all that will happen is the entire center shock will spin and you will get nowhere.
The front I was able to leave them bolted in at the top and loosen the center nut with no problem but the backs didn't.
Mike
Old May 27, 2006 | 02:29 PM
Spirit Rx-7's Avatar
rotard
yup, make sure you have an impact gun for the rears, and a spring compressor. other then that its stright forward.
Old May 28, 2006 | 12:21 PM
87_rocket's Avatar
gotNOS?
Will the car look weird with my stock phone dials after its been lowered?
Old May 28, 2006 | 12:33 PM
jgrts20's Avatar
Who are you?
get a haynes manaul, theres step by step instructions on how to replace the shocks/struts/springs.
Old May 28, 2006 | 01:45 PM
slow_2ed_gen's Avatar
maybe, i dont think i've seen any lowered with the phone dials on.
Old May 29, 2006 | 01:39 PM
87_rocket's Avatar
gotNOS?
Once i've used the spring compressor to compress the spring, what do i do about the strut? Will it be under significant pressure that will make it difficult to remove or require special tools? If i simply unbolt it would i wind up wearing it ?
Old May 29, 2006 | 01:42 PM
liv's Avatar
liv
New User
how much will a shop charge to do this
doesn't seem worth the hastle to me if they only charge 100 or so bucks
Old May 29, 2006 | 02:03 PM
compressing the spirng take the pressure off the strut
Old May 29, 2006 | 04:01 PM
1SWEET7's Avatar
I was quoted $270 to get mine done at a local shop. It cost me 5 hours and $10 for a spring compressor rental. Plus you learn a lot doing it yourself. The front struts will come off without problem because there is a notch to keep the shaft from spinning. The rears will take some thinking. I ended up taking the whole rear assembly out and using vise grips on the shaft, and a ratchet on the nut, I was able to get it off. Of course this won't work if you reusing your old struts.
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
