Air filter install Question
Old Feb 16, 2002 | 12:19 PM
Question Air filter install Question
Just bought a cheapo cone filter off of ebay that comes with an adapter. Besides taking out the stock filter box are there any other modifications need to be made. I presume more air will be flowing through now is there anything that I need to adjust?
Old Feb 16, 2002 | 12:28 PM
jizzajuice's Avatar
Nope, should be about it. You might have to rotate the AMS but that's pretty simple. ^_-
Peace,
AJ ^_^
Old Feb 16, 2002 | 01:37 PM
supergoat's Avatar
Eggs are like fowl cheese
You may want to get a smaller filter that can attach to the air pump inlet hose. But some people just leave that open.
Old Feb 16, 2002 | 01:43 PM
yeah what's that small filter all about I have seen tha bonez makes one at rx7.com
Old Feb 16, 2002 | 02:02 PM
spinner26's Avatar
The small filter you've seen is exactly that. As mentioned above it goes on your air pump inlet hose. You'll have a better look at it after you yank out the airbox.
Next thing you might want to do is make a heat shield to try and keep the hot under hood air away from your air filter. Search the forum for "heat shield" and you should find a couple examples that can be made in your bedroom for under $20.
Old Feb 16, 2002 | 02:16 PM
yeah an air box will be made, I can't beleive people are buying them for $100 or so.
Old Feb 16, 2002 | 04:30 PM
ianbell's Avatar
You don't need to spend $20 on a mini cone filter - check at the parts store for breather filters - I found one the same diameter as the air pump hose for $3.95 - works fine - and if you think you don't need it check the filter material after a couple of weeks - gone from virgin white to black!
Queppa
Nov 18, 2024 03:47 AM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rkhanso
Aug 13, 2015 11:40 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
