header install: need to remove ACV on S5?
Old May 26, 2006 | 01:36 PM
coldfire's Avatar
ERTW
I just received my collected RB header a few days ago. i was reading the instructions they gave, and the only thing i am confused with is the fact that it says on S4s you need to remove the ACV (they included a nice little blockoff plate with the header).
now, currently my car is a Series 5, with a Series 4 engine (the shortblock). The entire intake manifold is Series 5, as is the ACV. do i still need to remove the ACV? also,
- Why does the ACV need to be removed in the first place? clearance?
- If i remove the ACV on my S5, i am assuming the solenoids still need to be hooked up otherwise i will get CEL codes? there will probably have to be some sort of vacuum line rerouting also (oh joy...).
Old May 26, 2006 | 10:06 PM
Jager's Avatar
Tear you apart
ACV is removed because without a cat, it's worthless on an S4. You'll need it on an S5 for VDI.
That's about all I can help you with.
jeremyferguson4444
Sep 19, 2015 01:27 PM
