Do they make silicone vaccum caps?
Old May 25, 2006 | 12:29 PM
sunshine's Avatar
I've been using cheapo autozone rubber vaccum caps to cap some unused vacc nipples..but these peaces of sh*t are dry rotting in a matter of several months.
Is there a better alternative? Something that will last a bit longer? Better rubber, or silicone vacc caps? I'm not interested in using JB weld or anything permanent like that.
-a
Old May 25, 2006 | 12:53 PM
My5ABaby's Avatar
Rotaries confuse me
http://www.mcmaster.com/
lchaidez's Avatar
Caliente
which are the vacuum caps? the small thin ones? I use silicone... the only place i know is samco.com or hks.
I had a similar question about this except mine was in relation to "where can i exactly use silicone" but meh~ not like im any help anyways. Good luck!
Old May 25, 2006 | 01:34 PM
Rotary_Rocket_87's Avatar
2nd Gen. Enthusiast
Which vacuum caps from autozone are you using? The standard black rubber or the colored ones from the performance isle ( the one with all the chrome stuff for V8s)?
Old May 25, 2006 | 03:55 PM
sunshine's Avatar
The regular black rubber ones.
-a
Old May 25, 2006 | 04:08 PM
2nd Gen. Enthusiast
Go with the colored ones ( i think they are silicone) at autozone. The package has a few different sizes and they last along time.
Old May 25, 2006 | 04:14 PM
88rxn/a's Avatar
tom port.. AKA streetport
got mine form NAPA and never had a problem with them dry rotting..
just cheap ol black ones to
Old May 25, 2006 | 04:55 PM
Jager's Avatar
Tear you apart
I got the cheap black ones atm. When I send it to Kevin or Kahren, they can put on the nice caps .
Old May 26, 2006 | 07:22 AM
My5ABaby's Avatar
Rotaries confuse me
The cheap rubber vacuum caps aren't made to stand up to the heat of our engines. Maybe with a heat wrapped header they could... but I know with my stock manifold they go bad quick . I just had to replace 3 with under 2,000 miles on them.
dkwasherexd
May 27, 2017 04:51 AM
RotaryBobby
Aug 29, 2015 10:32 AM
succesfulljoe
Aug 20, 2015 08:59 AM
