I F***ed Up!!!
Old May 24, 2006 | 04:17 PM
LittleCon's Avatar
I F***ed Up!!!
so i got my shifter bushings today. I installed them very easly but as i was tightening the three 10mm bolts down on the shifter ONE OF THEM SNAPED OFF.
the head of the bold snaped compleatly off! Now i have the whole thread of the bolt stuck in there!!
i've never experianced anything like this and im not sure what to do! Can i still drive it to the shop?? will they be able to take care of it???
man, im freaking out, i was so looking foword to driving it today
Old May 24, 2006 | 04:20 PM
Icemark's Avatar
drill it and Easy Out (tm) it
Old May 24, 2006 | 04:21 PM
LittleCon's Avatar
? easy out?
sorry im still really new to this
Old May 24, 2006 | 04:22 PM
classicauto's Avatar
Crash Auto?Fix Auto.
just weld the cap on
thats a joke by the way
You should be able to extract it given that its not seized in there. Damn near every auto store should have a bolt extractor set, and its money well spent too. Make sure when you're drilling it that you don't go cockeyed in the hole.....and center punch the bolt before you drill so you don't walk the drill around it or 1/2 an hour.
edit: a basic extrator set is a square tapered punch with teeth that will bite in whe its turned counter clockwise. You drill a pilot hole in the bolt - hammer the extractor in and crank that **** outta there
Old May 24, 2006 | 04:23 PM
Icemark's Avatar
Easy Out= Bolt extractors
Old May 24, 2006 | 04:25 PM
RexRyder's Avatar
get a hammer/pick and hammer it out very carefully. Then when its out enough get some pliers and take it out.
Old May 24, 2006 | 05:07 PM
LittleCon's Avatar
gotcha, thanks guys
Old May 24, 2006 | 07:04 PM
Innovation's Avatar
Or if the bolt head is high enough you cut a slot with a drummel and take it out with a slotted screw driver. Done it many times.
Old May 24, 2006 | 07:41 PM
LittleCon's Avatar
i jsut tapped it with a flat head screw driver and a hammer, came right out
Old May 24, 2006 | 10:08 PM
WonkoTheSane's Avatar
Green Flameless
THis will be a VERY valuable skill to learn as you work on older cars Especially once you start getting down to the underside/rusty bits...
Old May 24, 2006 | 11:57 PM
Tournapart's Avatar
RIP Icemark
broken off RUSTED for a million years bolts are the most fun to take out
Old May 25, 2006 | 12:37 AM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
oh quit being a drama queen and take it out.. if you work on cars it happens.. i have done that to those bolts on more than one time.. i take the damn thing out and replace it with a better bolt.. i broke them using minimum torque maybe they get old...
Old May 25, 2006 | 12:38 AM
fidelity101's Avatar
Rallye RX7
yeah except when I keep breaking drill bits, titanium my ***...
Old May 25, 2006 | 12:59 AM
rotaryroket87's Avatar
braaaaaaaaaaaaaa pshhhhhh
left handed drill bits take them all out and there cheap
Old May 25, 2006 | 01:01 AM
bjf498's Avatar
last bolt i broke i welded a bolt on top of it and just backed it out
