What would make my turbo glow?
Old May 24, 2006 | 12:35 AM
jeff_man's Avatar
N00b
So i drove home tonight not pushing it, 75% of the time 4&5th doing 55-65mph and drive 2 miles, pushed it for about 1/2 a mile then drove 5 more miles home. popped the hood when i got home and the turbo was glowing a little. few nights ago i was running normal for about the same drive with out any pushing and it was glowing alot. what could be causing it the glow?
Old May 24, 2006 | 12:38 AM
cptpain's Avatar
Torqueless Wonder
you are possibly running a bit lean
Old May 24, 2006 | 12:53 AM
jeff_man's Avatar
N00b
no way to tell and i have a RB FCD, trying to get a air/fuel put in on my narrowband
Old May 24, 2006 | 06:33 AM
dhahlen's Avatar
FD Under Construction =P
timing...
Old May 24, 2006 | 07:12 AM
hondahater's Avatar
spending too much money..
^^^ what he said!
Old May 26, 2006 | 12:08 AM
lowkee33's Avatar
Slo Low
Yes sir I will triple that comment!
Old May 26, 2006 | 08:17 PM
PSI R2's Avatar
If you still have a cat it could be burned up. cats
Old May 26, 2006 | 09:20 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
or you could just be stepping on the gas. turbos glow.
Old May 26, 2006 | 10:11 PM
impactwrench's Avatar
Normal. They do that. Don't worry about it. If you don't have a turbo timer"for people who should not own turboed cars", let it run a minute or so, before you shut it off.
Old May 26, 2006 | 10:14 PM
red87tll's Avatar
needs a cheaper hobby
lean, timing, exhaust.......
Old May 26, 2006 | 10:17 PM
a turbo not glowing is like a guy in a porno theater NOT having a boner.
Old May 26, 2006 | 10:22 PM
Agreed, don't go there if you are not prepared for the consequenses.
Old May 26, 2006 | 10:23 PM
JIMLAB, where are you?
Old May 26, 2006 | 10:24 PM
hondahater's Avatar
hahah too funny! true very true I should have said that first i guess. I was thinking it was abnormally glowing like just at idle but i guess thats what i get if I ASSume ****.
Old May 26, 2006 | 10:29 PM
Juiceh's Avatar
Saiga-12 Power!
If your leading coil isn't firing it will make your turbine glow as well. Similar to having a timing retarded too much except probably alot more of the combustion is occuring in the turbo. But if your leading coil is toast your car will be hard to start as well. I had a crane ignition box installed improperly by a "professional" and it blew up 2 sets of leading coils. Car was a bitch to start, boosted like mad but had no power and after a short drive the turbo hotside glowed... pretty bright glow too.
Old May 26, 2006 | 10:35 PM
I have seen my turbo glowing so hot that it looked a couple of degrees from melting. I am amazed that it keeps spinning, and without spewing oil, time after time. I will continue to abuse it, fondle it, torture it, covet it, full throttle it, until it is dead.........I fear that it may outlive me.
Old May 26, 2006 | 11:09 PM
yea, other than normal operation, common stuff that will make the turbo glow:
too much or too little fuel
too much or too little timing
MISFIRE! ( coils, ignition, etc)
plugged exhaust
cristoDathird
28
May 30, 2019 08:47 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Microtech
Aug 23, 2015 11:04 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
