What would make my turbo glow?
Old May 23, 2006 | 11:23 PM
jeff_man's Avatar
N00b
s4 block with s5 turbo and it tends to glow every once and i while? is that ok for it or is that bad, i really didn't push it that hard tonight on a about 7 miles drive mostly in 4th and 5th
Old May 24, 2006 | 12:33 AM
RevinRx7's Avatar
Concerned Citizen
Originally Posted by jeff_man
what would make my turbo glow?
.....Using it..
Old May 24, 2006 | 12:46 AM
RyosukeFC3C's Avatar
heat...:P
check the oil lines, if you're not boosting it it shouldn't be glowing though
Old May 24, 2006 | 12:54 AM
jeff_man's Avatar
N00b
Originally Posted by RevinRx7
.....Using it..
no ****, only proble is it's bad for it
Old May 24, 2006 | 01:12 AM
SirCygnus's Avatar
whats going on?
who says?
Old May 24, 2006 | 01:14 AM
Boostmaniac's Avatar
An EXTREMELY lean (read: dangerous) condition can also cause that. Also rearding the timing ALOT (I don't think it is even possible on a rotary to retard the timing that much though) can accomplish the same result.
Check for clogged cats also, any clogs will cause heat to build and occasionally heat the exhaust to glowing temperatures.
Rule all of these out before you try to drive again.
btw, are you still using the stock iron manifold?
Old May 24, 2006 | 01:26 AM
DC350's Avatar
Rotor Head
If you're driving it hard its normal i'd say! i drive extra hard sometimes just to see it glow!! :P
Old May 24, 2006 | 03:06 AM
xzyras's Avatar
I don't have 3rd gear
It's normal. You should have a shield on it. That way you don't see it glowing bright orange and won't worry. Our cars make way more heat, thats why we always have cracks on the hotside and manifold. Get a shield before you melt all your wires and vacuum hoses.
Old May 24, 2006 | 04:02 AM
13b4me's Avatar
Running extremely rich will also cause it to glow, due to unburnt gases being ignited by the heat of the turbine housing... Been there...
Old May 24, 2006 | 10:01 PM
T2 FC3S's Avatar
I have the same problem and always wondered what caused it. I always though it was normal though. Plus im running really rich. about half of the down pipe glows alittle too.
Old May 25, 2006 | 09:10 AM
Aaron Cake's Avatar
Engine, Not Motor
If you are beating on the car and look at the turbo right after some hard driving, expect it to glow. That is normal. If it glows at idle or during light driving, then the car is running way too rich.
Old May 25, 2006 | 01:24 PM
jeff_man's Avatar
N00b
Who my premix be making it run so rich it glows?
Old May 25, 2006 | 03:23 PM
Aaron Cake's Avatar
Engine, Not Motor
I doubt it has anything to do with premix.
Old May 25, 2006 | 03:24 PM
13b4me's Avatar
Premix should have nothing to do with your turbo glowing...
cristoDathird
28
May 30, 2019 08:47 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Microtech
Aug 23, 2015 11:04 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
